Question about Casio EXILIM Card EX-S770 Digital Camera
Battery charger my casio exilim np-20 won't charge it just flashes when ever i try to charge it. The camera won't operate and the charge light just keeps on saying it is charging even after two days. I ordered and replaced the battery with a new one but the problem is still the same.
  • 6,487 Answers
If a new set of batteries still doesn't work, then it's some sort of camera error, but you may still be able to get it fixed. Despite the fact of not having a receipt, if it's an issue of faulty manufacturing the company may help you. Check your user's manual for a customer service number and call Casio.
Good luck.......
Posted on Aug 26, 2008
  • 4,472 Answers
Have you tried cleaning the contacts with alcohol on a cloth? If that doesn't work it may be a problem with the camera. How long have you owned it?
Thanks,
Lee
  • Lee A.
    Lee A. Aug 26, 2008
    Also one solution is to buy a universal external charger and charge the batteries with that. Then you can still use the camera.
    Thanks,
    Lee
Battery flashing when charging why?
If the red light is flashing after inserting a NP-20 battery in the Casio Lithium Charger BC11-L, it means that the battery will not take a charge. Normally when putting the batterry in the charger, the light will be a constant red. After charging is complete, the red light will go out. Battery is then fully charged and ready for use.
Mar 19, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio NP20 battery does not charge,charger keeps flashing, does this mean I need new battery? also,it has 700MAH will 800 do when I replace it? was does this mean
If you have had the battery a long time or have charged it often it will need replacing if it does not charge.
800MAH is the capacity of the battery, how much power it can store.
800 is better than 700 and if it is a NP20 it will be OK in your camera.
Hope this helps.
Feb 21, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
The camera ran out of charge and now when i put it in the charger it wont switch on or charge up and the charge light is flashing intermittently. Thanks
I found this while trying to solve my very similar problem. It worked for me after about 7 times. Other people wrote that it wook them 20 times... good luck!
ylu1 writes:
what i did was...
hope this helps.
My Casio Exilim EX-S880 wont charge. when i put on the charger the red light blinks but it is not charging.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
ylu1 writes:
what i did was...
hope this helps.
Jul 16, 2009 | Casio Exilim EX-S880 Digital Camera
When the battery is in the charger it flashes red & won't charge, have no idea what problem is! Have casio exilim lithium ion NP-20 battery & a casio exilim 7.2 megapixels camera. Can't turn camera...
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Jul 08, 2009 | Casio EXILIM Digital Camera
Casio exilim ex-s880 wont charge battery has been replaced and when on the charging dock charging light just blinks
I had the same problem. Here's what I found that worked for me. I had to do this about 7 times but others that I read had to do it about 20 times but worked for them as well. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Feb 22, 2009 | Casio Exilim EX-S880 Digital Camera
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
Casio exilim camera charger
I read that if you connect a 9V battery (+ to +, - to -) to the NP-20 for 10 seconds, it will jump start the battery and provide just enough charge for the battery charger to recognize the battery. The problem is that the NP-20 battery becomes so low that the charger will not charge it. I also read that you can use 2 D size batteries if you don't have a 9V battery.
Just make this connection to the NP-20 battery, not while in the charger! Only connect it for about 10 seconds or so. Everyone who tried it was successful and the battery would charge when it was put back into the charger. There should be no need to buy a replacement battery.
Jul 02, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
41 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
