Question about DeLonghi DH100P Dehumidifier
De Longhi DH250R AriaDry Combi Dehumidifier
I was given this dehumidifier when my mother passed away and prior to that she swore by it. Since I have had it, it doesn't seem to **** up any water. If it is knocked, the 'full' light is illuminated but it is in fact, bone dry. The heater on it is fantastic and works well but there is no water! I have been trying with no luck to locate a manual for it which would help with troubleshooting. Please help as I really need it to work at the moment.
Check your water tank. On the inside is a lever and a slot. Wiggle it till light goes off. Should work after that.
Posted on Jun 26, 2010
I have a De Longhi de500p. Runs and I can hear the compressor kicking on and run. But I am not getting any water in the tank. Room temp 75 degree and humid meter set at 40 .Please give me some advice
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
Aug 31, 2011 | DeLonghi DE500P Dehumidifier
How to fill with gas my de longhi type DH 40 pints. It works with R 22
You shouldn't be using R22 anymore as it is being phased out and is bad for the environment. If it is not working, you might want to call in a pro to do the job. They'll have to hook up the dehumidifier to a manifold to essentially **** all the R22 out, ensure that there are no leaks, and replace it with a R22 substitute. It's going to take a few hours, so be prepared to pay $$$. The alternative is to bring it to a municipal recycling center or whoever that will accept it and buy a new one. You can't just throw it away.
Aug 10, 2011 | DeLonghi DE40P Dehumidifier
De Longhi dehumidifier DD40P Not collecting water.
Jul 27, 2011 | DeLonghi Dehumidifiers
Where to go for spare parts for dh250r need circuit board for compressor
Glenn, here is a link to Delonghi Parts and Accessories website. You can order parts there if you have the Part Number. Or you can call Delonghi at 800-865-6330.
Hope this helps you find the part your need.
Apr 28, 2011 | DeLonghi DH100P Dehumidifier
follow the instructions below on how to use your dehumidifier:
Prepare the room for the dehumidifier by vacuuming, dusting and cleaning the room. Be especially careful to have all mold removed prior to using the dehumidifier.
Plug in the dehumidifier into a grounded outlet.
Set the dehumidifier to high in order to remove excess moisture from the room.
Wait for the dehumidifier to run several cycles, removing all undesired moisture from the air. This may take days or even weeks in especially damp rooms.
Adjust the setting of the dehumidifier when the air has reached your desired comfort level. Make the setting one that will maintain the current conditions.
Good luck.
Aug 16, 2010 | Woods WD25G Dehumidifier
Dehumidifier throws off hot air making the room very warm. Is that normal?
Yes! A dehumidifier is an entire AC system in one box. First the air passes thru a very cold coil causing moisture in the air to condense and run away. Then the air is re-heated thru a hot coil (the other half of the AC) and blown back into the room. The net result MUST be a net increase in temperature because of the heat added by the mechanical process.
May 17, 2009 | Goldstar DH504EL Dehumidifier
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
Apr 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
DeLonghi DH100P Dehumidifier Logo
2,375 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
