Question about LG GCE 8481B CD-RW Burner
Audio works but not installation disk
My cd drive works fine for audio, but when i put a factory installation dvd disc into the drive, the drive doesn't recognize the disc. It is supposed to be a dvd RW cd drive. gce-8481b
Any ideas? It's a used computer. I've updated XP, and all the drivers i can find but.... ??
Thanks
    Genius:
  • LG Master
  • 1,250 Answers
HEY is it playing other DVD'S check is it a combo drive , dvd wirter or a cd writer, if its only a cd wirter then it won't play DVD
Posted on Nov 20, 2008
Refer Acer m3970 Can not Install windows 7 of new hard drive
Factory back-up discs and recovery discs are intended to repair defective installations or to kick-start an installation that refuses to start so it is unsurprising they will only go so far.
Your system disc might be defective. This is a problem I have had with XP in the past. It is possible your CD/DVD drive has a dusty lens and is unable to read the disc properly or perhaps the new hard drive has a problem.
I suggest you instal the new hard drive as a slave in another computer and format it and run the chkdsk utility. If all is well reinstal in your computer.
Take a close look at your system disc checking for flaws and perhaps put a lens cleaning disc in your CD/DVD reader before trying again.
Oct 27, 2016 | Seagate Computers & Internet
My Yamaha CDR D651 appears to dislike new 50x maxell CD-r discs saying not audio. Works fine with 12x discs. What's wrong? Rowan
you probably have regular cd-r disks that cannot be recorded on in this unit. You can only use disks marked "DIGITAL AUDIO" for recording
Sep 16, 2014 | Yamaha CDR-D651 2-Disc CD Recorder
DVD drive won't read original microsoft office installation disk - it will read other disks. Also the microsoft disk can be read from DVD drives in other computers.
First are you CERTAIN the computer you are using the dvd in is capeable of reading dvd discs? If so I'd recomend purchasing a cd/dvd cleaner (available online and in most audio shops) and a CD Lense cleaner.
This should cure your problrm, unless it's one of the first signs of the laser wearing out, in which case a replacement drive is required
Jan 16, 2011 | ASUS Computers & Internet
My hp nc4200 has no operating system how do i install windows XP professional
Hi
Do you have a disk with the operating system on becausse you will need one
Then put it into the disk drive restart the laptop pressing F12 a few times as it starts up and then choose the d drives to run the cd installation the computer will then hopefully start up and say press and key to continue
Nov 15, 2010 | HP Compaq nc4200 Notebook
It doesnt rcognise the recovery disc 1 year ago my son formatted the hard drive soi installed windows xp from a new disc, and it worked fine untill now when th pc ceased to work properly. so i put the xp...
probably ur cd/dvd rom drive is down or the cd frm where u r installing is corrupted..copy it from elsewhere n try..or try downloading....
..contact ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
My disk drive is not working i am trying to down load a new program and when i put the disk in it will read it and then error appears
Hi saratrought, if Windows XP runs and you have read problems in CD/DVD drive try to read another disk, if any other disk work fine then you need to copy your CD/DVD info (or program) in another new disk.
Or just use Windows Explorer to try copy all data from CD/DVD disk to a New Folder in your Hard Drive and then from that location you can try to install your program, if your data don´t copy well then again i tell you that it´s your disk not your CD/DVD drive.
Sorry by bad english.
Oct 16, 2009 | Dell Inspiron 6000 Notebook
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Disk not detected
Hi, had the same problem myself, turns out (after some investigation) that the motor that spins the dvd wasn't getting power. I carefully pulled out the smaller ribbon cable that goes to the small circuit board beneath the drive caddy, then pushed it back in. Put it back together, turned it on and off it went! Yay!
Mar 18, 2008 | LG DVD 6183 DVD Player
Only reads some disks.
Hi, if the PC's are older than 3 years or the cdrom drives are near it's end of life, it will make problems to read some CDR's. If you recorded the CD's you are trying to read, try recording at less than 4X speed.
Sometimes, even "original" or "silver" CD's will make problems because they are not recorded correctly at the factory.
If the problem is with a CDRW drive, it applies the same theory, the recording laser is damaged or used up. It will not record a legible CD or DVD even if the software says that the record operation ended successfully.
Feb 09, 2008 | HP Pavilion dv6000z Notebook
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
LG GCE 8481B CD-RW Burner Logo
91 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
