Question about Profile 600MSX Car Audio Amplifier
Whenever i wire 2 4 ohm svc subs the system just starts to pound real hard and its not like bass moving to music but just bass just moving up and down
Ok so i bought a profile california 600msx mono amp when i hook up my subs to it, it just starts to make them pound up and down and thats it. no bass type deal to the music its like boom,boom,boom,boom, no like boom,boom,boomboomboom,boomboom but just straight boom.
  • 631 Answers
It sounds like you have an open shield ground. To check the shield in your head unit, read through the following page.
Temporary Shield Ground Repair
Let me know if you have any other questions.
Posted on Aug 26, 2008
Wire 2 sub 4ohm
I am assuming these are subs, you didnt say, but that is my guess. do you want bass, or do you want to take it easy on your amp? do you have a terminal cup on your sub box, or just wires going into the box to the speakers? take it easy route: wire positive from amp to positive of one speaker, negative of amp to negative of the other speaker, with a jumper wire connecting the negative of the first speaker, to the positive of the second.
more bass route: run seperate positive and negative wires to each speaker, making sure to maintain proper polarity.
Oct 21, 2013 | Jl Audio 500/1 Car Audio Amplifier
What way should I hook 2 12" jl audio to a jl audio 1000/1
Is this sub an svc or a dvc? From what I looked up they are svc, so each sub's voicecoil is 3 OHMS, connecting them in parallel would lower them to 1.5, and your amp is capable of going down to 1.5 ohms. So I would suggest running them in parallel.
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
(Although from the information I gathered these subs have 3 OHM voicecoils, so in the diagram where is says 4 OHM it should say 3 OHM, and the 2 OHM should say 1.5 OHMS.
This is a good site to help calculate OHMS: http://www.bcae1.com/spkrmlti.htm
Hope this helps.
Nov 11, 2010 | Jl Audio 12W7 Car Subwoofer
I play my music on low and it has bass wen i turn the radio up it starts hiting only certain bass notes the lowest dont hit hard it starts sounding weird???? i have it hooked to a audiobahn aw1206t...
sounds like you have some wires crossed. check your radio setting and make sure that the subs are only playing bass and no trebble. buy some new rcas
Mar 10, 2010 | Nitro BMW-486 Car Audio Amplifier
Need more bass
Bridge it. Should be marked on amp. According to specs should get u the power u need. Amp max 1500 watts. at 2 ohms. Speaker max is 2200 watts at 4 ohms. Turn amp down and adjust to your own taste. trust your ear man.
Jul 12, 2009 | Car Audio & Video
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
I HAVE A JL AUDIO MONOBLOCK AMP 250
there could b allot of factors involving this problem first could and most important is to make sure theres no loose connections in your wiring and find out how ur subs are wired in. are they SVC or DVC (single and duel voice coils) also what are theyre impedences if SVC could be 2, 4, or 8 also the same as DVC but jus 2 sets of terminals. find out first then the reason i ask is cause allot of half way manufactures are installing a device u could say that will cause amps to automatically cut off when the load on the amp reaches its lowest impedence load so when ur subs are moving in and out that load varies with how far the sub is extending out jus cause a sub say its a 4 ohm SVC doesnt mean that when its pounding away the load may actually be 3 ohm when fully extended. find out these variables first and then reply and ill let u know what to do properly.
Jan 16, 2009 | Jl Audio 250/1 Car Audio Amplifier
Constant sound from subs
I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
Jan 09, 2009 | MTX RT2200 Car Audio Amplifier
12 w 3 v3 2 cut off
Again as I have stated in my other answer to you. You can not wire two SVC 2 ohm subs to acheive a 2 ohm load. more than likely you are running your amp at 1 ohm mono and this is why it is clipping and shutting off.
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Dhd ntx 2009
With two 4 ohm svc subs and a 4ch amp the best way to hook it up is as you have described. There is no way of wiring it to get a lower ohm with your set up.
Aug 28, 2007 | DHD NTX-2009 Car Audio Amplifier
Profile 600MSX Car Audio Amplifier Logo
398 people viewed this question
Top Profile Car Audio & Video Experts
xxxxxx xxx
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
