Question about Toshiba CT-9995 Remote Control
Batteries are good. However TV isn't on right channel to show any programming what to do?
  • Toshiba Master
  • 2,098 Answers
Hi William,
To confirm if the remote control is working fine, aim the infrared emitter of the remote control to your cellphone camera, press any button key and check if the infrared will flash to your camera. Watch this video on how to do this trick.
Also, does the front panel button key of the TV isn't working?
Jdvillanueva
Posted on Jul 09, 2011
SOURCE:
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
The picture isn't very clear. What can I do?
If some channels are good but others are poor it is not the set. These sets are all much more critical for signal being good than the older sets--they will show noise etc a old set would not even show.
A dead give away is if DVD or Blu Ray etc looks great but TV channels do not---it is not the set.
Apr 28, 2012 | Viore 37" Class LCD 1080p 60Hz HDTV,...
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
I got a sony bravia kdl46nx800 led tv and for some reason, there is a green line on the right edge of the screen on certain HD channels and not on regular channels when i watch the shows. it is a common...
Hi, I can't say I've ever seen that happen with that TV before so I'd say it definitely isn't common. I'm pretty sure it's the signal from the HD channels, I'd suggest talking to your cable service provider.
May 14, 2011 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Screen is all snow and channel 4 shows in the upper right hand corner. TV needs to be on channel 3, but trying to change it manually does not work; therefore, satellite tv does not work. I've checked...
Check your TVs settings. Check if channel skip option in on. If it is on, this type of fault occur. Turn it to off if it is in on condition. If the blue back screen option is there, just turn it on to avoid grains on unused channels.
Oct 13, 2010 | RCA F32649 32" TV
Toshiba CT-9995 Remote Control Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
