Question about Toshiba Gigabeat MEGF40S MP3 Player
I have the Gigabeat F40 and I recently installed the Gigabeat Room 3.0 but I can not copy any file to the gigabeat. "An error occurred in coping or moving to the gigabeat" I'm using windows vista. Any ideas? Thanks!
SOURCE:
SOURCE: Vista recognises Gigabeat F40 as a hard drive and not an Mp3
try using windows media player 11 and go sync the MP3 player using that method. if you click on my computer and click on the device highlight the music you want from your device to your computer and copy them to your music file.
Posted on Dec 05, 2008
SOURCE: Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Posted on Dec 29, 2008
SOURCE: Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Posted on Apr 10, 2009
  • 6 Answers
SOURCE: Gigabeat room will not recognize my gigabeat
I was investigating other Toshiba F40 issaue and came across this thread. This might help you.
http://www.associatedcontent.com/article/30962/using_your_new_toshiba_gigabeat_tips.html?cat=15
Posted on Jul 30, 2009
rcalorisian
  • 313 Answers
SOURCE: I need to copy music my PC to my Toshiba gigabeat f40 GB MP3
You can download the sofware and the manual at the link below.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2288415&rpn=&modelFilter=MEG-F40&selCategory=6&selFamily=727858
I hope this helps you...
Don't forget to rate me if this helps you...
Good listening...
Posted on Sep 17, 2009
Toshiba Gigabeat Touch Controls broken - need to transfer music to iPod
remove front cover on Gigabeat F40, remove battery. on back of battery a spacers remove those and replace with thinner spacers. I used hi quality insulation tape three layers of and stick back onto battery. Install battery again and it will have fixed the problem. Did it with mine
Jun 15, 2012 | Toshiba Gigabeat F40 40 GB MP3 Player
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
System error 00200060 NO SYSTEM FOUND ON HDD ona Toshiba MEGF40. I tried firmware upgrade, reformatting but not working hellp me
Okay, here's what you need to do. I'm assuming at some point yours like mine was formatted under windows. This is bad for them lol. Locate your copy of gigabeat room, and install it. This comes with a extra program in the start menu titled formatting utility for gigabeat. Format with this program, and then look under program files/toshiba/gigabeatroom/GBsystem. Copy GBsystem to the gigabeat, then turn the battery off with the switch on the bottom for thirty seconds. That should do it.
IMPORTANT NOTE!!!!!!!!!!!
This can only be done with a computer running USB 1.0. My newer computers could not "see" the gigabeat properly. I used an old machine with outdated USB to get mine to work again :) you can also check for aftermarket firmware called Rock Box, just installed that one mine, no more converting music to *.sat, it'll take straight mp3s now just like it should :) uploaded 20 gigs to it in less than half an hour :) beats the hell out of waiting ten hours for 8 gigs lol!
Jun 14, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
How do i convert mp3 music to wma.sat for my gigabeat f40? when i copy the mp3 files into the gigabeat player it cant be played..
You need a format converter to convert the mp3 to WMA. You can download a free format converter at the following website:
http://www.formatoz.com/
Good Luck, I hope this helped you Please rate me, Thanks
Dec 31, 2009 | Toshiba Gigabeat F40 40 GB MP3 Player
Mar 30, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Cannot Instal CD for Toshiba Gigabeat F40 on Windows Vista
Download the MEGF Series Update 3 from Toshiba's website
Nov 10, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
No gigabeat room
hola formatie el gigabeat f40 y me aparese error de system porfa me puede ayudar mi correo es [email protected]
Aug 20, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
I need to reset the entire program on the f40. System settings and all
The EASY but Time consuming way (If you Only hagve USB 1), is to just RESET the unit.
The manual will run you through it, and reload.
I have both Gigabeat Room, and Win/Player 11, and have reset and reloaded a few times.
Just take some time (Specially with Gig Room)
Good Luck
Jun 13, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Toshiba Gigabeat support is 1-877-250-8595
Sep 29, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEGF40S MP3 Player Logo
97 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
