Question about Fuji FinePix 2400 Zoom Digital Camera
Finepix 2400 Dark landscape shots
Please help I have a recently purchased Finepix 2400. With the camera set on auto I am having problems with landscape long distance shots once the picture is taken then down loaded on the PC the picture is very dark. There is no problem with close up or macro shots these all turn out great. Can anyone advise on what setting/set up needed for good landscape shoots
    Master:
  • 425 Answers
I think I have cracked it bright sun light use +3,6,9 etc depending brightness
Posted on Sep 04, 2005
    Master:
  • 425 Answers
I was just out yesterday taking pictures in very hazy conditions, and some of my shots were facing south at about noon. I was actually expecting the sky to be overexposed, so I took two pictures of everything, one on auto, and one on manual with the exposure set to -0.6. Well, it turned out that even the ones on Auto were dark, so the ones on the manual settings were even worse! As it turns out, I had the same problem you had, and should have boosted the exposure. Reading the manual, it does say that you should use positive compensation for very bright scenes or pictures of mostly sky. Try it next time and see how that works. I'm new to this too, but I'll get the hang of it sooner or later... ;)
On auto setting my pixs are coming out too dark.......solution?
Go into the menu and reset all settings back to default. Then make sure you have the flash set to AUTO... if it's too dark, the flash should be on!
Hope this helps...
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Fuji FinePix S1000FD Digital Camera
I recently purchased a canon g11 and wonder what settings are best on the camera for group shots of 12 or more for a clear shot of everyone? they are usually taken under flourescent lighting conditions.
Put the camera on "auto ISO". Set the white balance for "auto white balance" and take a test shot. Then set the white balance for "flourescent" and take a test shot. Pick the best option.
Mar 13, 2010 | Cameras
Finepix E550 -suddenly very grainy photos and over exposed?
Have you checked what ISO you have selected here?
Graininess and over exposure can be caused by selecting the wrong ISO ( which in film days was ASA ( film speed) The average ISO should be 100 some early models allowed ISO 64 or similar. Having it set at 400 -800 ISO can also have the pics come out grainy. But not nescessarily overexposed unless you point directly at the light source as these ratings are for low light/movement situations. The video mode usually sets itself up differently to picture mode. The fact that you say your video is OK says there is nothing wrong with the lens or sensor, just the settings you have initially chosen to have autoed.
Please rate our help to keep thye service online++++Thanks for using FIXYA
Sep 19, 2009 | Fuji FinePix E550 Digital Camera
Fuji Finepix s1000fd-issues with color and brightness
hi.. I have the same problem. you must download and instal a new firmware. factory firware is 3.3, and the newest is 3.5. they solve the color problem..
Sep 06, 2009 | Fuji FinePix S1000FD Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
May 15, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Brightness
kindly provide me with contact details of your repair centre in New Delhi, India. I have fujifilm f420 finePix digital camera and facing problems inusing it.
Regards
Alok
alok.tanwar@gmail.com
09818000602
Sep 12, 2005 | Fuji FinePix F420 Digital Camera
Several shooting modes
The Shooting modes are as follows: Program Auto (Factory default setting) Used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering can be adjusted manually. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the Wide position and cannot be changed. Portrait + Landscape Portrait + Landscape mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Fuji FinePix 2400 Zoom Digital Camera Logo
87 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
