Question about Emerson Black Microwave Oven
EMERSON MW8998B hi i have a emerson MB8998B the light comes on and the timer starts counting down but the turn table doe not turn and you cannot even her the motor on.
  • lkmmorris Aug 26, 2008
    I have the same problem with my new Emerson MWG9111SL microwave. Lights come on(electricity to unit), the timer starts counting down but the turn table doesn't turn and you can't hear the turn table motor.
    Help!!!!!!!
  • donyraghadee Sep 14, 2008
    I have the same problem with my MW8999RD 0.9 cu ft900 Watts Stainless steel Red coloured Emerson Microwave Oven, The lights turn on, the timer starts working but inside the microware, the disc doesnt rotate adn the thigns do not get heated up. Please help me
  • Emerson Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Posted on Sep 02, 2008
  • LaVita Jan 30, 2014
    I have an Emerson mw9117w and it is doing the same thing. Do I need to remove the control panel to test the door switch? And do I need to test to see if the door switches are getting power? THANK YOU!!!
Emerson Microwave MW9117W. Timer Counts down and turn table stops, but continues to hum as if microwave is still running. Have to unplug to stop it. Anyone know what problem is? Thanks
Sounds like you have a ''smart board" or door switch problem, try to un plug the product, push all the 'buttons' on the control panel and then plug the product back in, if this does not correct the problem you have a component that has failed.
Jan 09, 2015 | Emerson Microwave Ovens
Does not heat and does not turn but does count down and timer works but still not turning or sound of heating motor or no nothing
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 01, 2010 | Emerson Black Microwave Oven
MW8998B manual has been lost I need to be able to download to figger out how set for regular settings not just quick minutes
Please find the details of the manual from:
http://kitchen.manualsonline.com/manuals/mfg/emerson/mw8998b.html
Please open the above link on the computer IE window. And then click on GET THIS MANUAL to save it to your desktop.
Please rate me if you are happy with the information provided.
Sep 15, 2009 | Microwave Ovens
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Jan 19, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
No light, not heating
You are entitled to a refund, or a new one, i would go back to the store where you bought it and demand a refund, because you are entitled to one.
Jul 19, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson Black Microwave Oven Logo
580 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
