Question about Whirlpool Washing Machines
Washing Machine Stopped
Hi!  Our washing machine stopped on the spin cycle leaving the drum filled with water.  We can only get it started again for a few minutes, but it always stops in the same place.  Yikes, our clothes have been sitting in the water for over a day now and we can't figure out how to get it working again!
Thank you so much for your help
  • 497 Answers
I guess u cud reset the timing of the cycle....also check the water inlet and outlet connections
Thanks for using Fixya!
Posted on Aug 26, 2008
Hi, have a problem with my hotpoint wfm940 washing machine. It had an error f5 which relates to the drum not draining, found rubber bands in the pump. Machine isn't running any cycles now, it will spin,...
Try removing the plug or switching off the washing machine and leave it for about ten minutes. Hopefully this will reset the electronics and allow normal operation again..
Jan 02, 2014 | Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Machine filled up, did the wash cycle but has completely stopped when it should drain. If I reset it, it will spin again, but again stops at the drain cycle. Help?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 24, 2011 | Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    I started my machine and it started to fill and then I stopped to add a couple more things and I can't get it to restart. help
    switch the power off for 1 min. then plug power back in and select spin cycle.(to get rid of the water. When all water is gone and drum starts to spin, switch off again. Select the normal wash you use all the time and see if all is ok.
    Sep 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
    Doesnot stop filling water
    To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
    To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
    Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
    I have a WF220, 1200 spin washing machine (3.5 years old and very little use) which does not complete the washing cycle. Each light comes on as the programme progresses until all the lights are lit...
    You may find that the internal filter is blocked & that by stopping and starting the machine you are giving it extra time to complete the drain cycle. The filter is located at the bottom rear of the machine & is secured by a large hose clip to the bottom of the drum. Try filling the washer with no clothes in & then switching to the drain programme to see if the water drains properly
    Nov 03, 2008 | Washing Machines
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
    sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
    Apr 22, 2008 | Washing Machines
    Wash starts it fills with water then stops and wont wash
    problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
    Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
    Washing Machines Logo
    96 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
