Question about Gateway (4000444) Motherboard
Jumper placement on motherboard
I have a gateway motherboard number 4000444 and am looking for a solution that will show me where to put the jumpers on the motherboard so i can test it to see if it works or not that way i may salvage it or junk it
    Novelist:
  • 125 Answers
Here this website has documented the jumper settings for your model motherboard with detailed pictures to go to
http://support.gateway.com/s/MOTHERBD/INTEL/m00061/M0006126.shtml
Goodluck
Please Dont Forget To Rate, Thanks :D
Posted on Aug 26, 2008
I am looking for the diagram about the power connection
Posted on Feb 04, 2010
Diagram for ms-6730 ver 1 motherboard ( jumper settings)
Manual for MS-6730 v.1 motherboard can be downloaded e.g. here:
http://www.retrevo.com/support/MSI-MS-6730-manual/id/17425bh040/t/2/
Aug 16, 2012 | Computers & Internet
For jumper settings
The eMachines T2200 Desktop PC uses an ECS L7VMM2 motherboard,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on Download.
[ Features/ Specification/ Download/ FAQ/ CPU/ Pinout ]
Click on Manual.
[ Driver/ BIOS/ Manual ]
At the bottom to the right of - Download Site,
click on the name of the country nearest yours.
In the small window that comes up on the right, make sure there is a green dot in the small circle, to the left of - Save File.
If not click on the small circle to the left of - Save File.
Now go to the bottom of the window, and click on OK.
Look at the top of the small window to the left. This tells you where the file will download to.
When you see the file name DOUBLE-click on it, and Extract all files. It is a Zip file.
Now DOUBLE-click on the red Adobe PDF icon, next to the extracted files.
Need guidance with this post in a Comment.
A) JP5 jumper is right below the Ram Memory slots.
CPU Frequency Jumper.
(Processor; change internal clock frequency - jumper)
Vertical placement. 3-pin jumper. The TOP pin is number 1 pin.
With the jumper on Pins 1 and 2, the frequency is 100MegaHertz.
With the jumper on Pins 2 and 3, the frequency set is 133MHz.
B) The small 4-pin connector above the CMOS battery is for an internal speaker. (For BIOS Beep Codes)
The small 3-pin jumper that is Horizontally placed above it, is the JP1 jumper.
Clear CMOS Jumper.
The pin all the way to the Right, is the number 1 pin.
With the jumper on Pins 1 and 2, the setting is Normal.
With the jumper on Pins 2 and 3, you are trying to clear cmos settings.
From manual;
"To clear the CMOS memory, disconnect all the power cables from the motherboard, and then move the jumper cap onto the CLEAR setting for a few seconds."
Ummm, NO.
Unplug the computer from power. Put the jumper cap on pins 2 and 3 for 5 seconds. Remove from Pins 2 and 3, and put back on Pins 1 and 2.
Plug the computer back into power.
WAIT 1 minute, turn the computer on.
Geez!
I don't see any other jumpers. Post back if I missed one, in a Comment, and/or for additional questions,
Regards,
joecoolvette
Aug 06, 2012 | eMachines T2200 PC Desktop
I need to find the motherboard wiring diagram for a Gateway 505gr
Look for a make and model number and version number on the motherboard, gateway use various manufactures motherboards.
Then go to the makers website and look in the support section for the moherboard manual. Most motherboards have the connections marked on the board in very small print.
Feb 11, 2012 | Gateway 505GR PC Desktop
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
How do I clear the BIOS password on a da0ma2mb6d8 motherboard?
Hi.
On almost all modern motherboards there is a jumper(it should be labeled on the motherboard).
Look on the board, and remove the jumper, and boot up without the jumper in place.
This should reset the passwords back to factory....usually means that there will be no password.
then turn power back off, and replace the jumper again, and then boot up again.
Your system should now be bios password free, and you can go into the bios and set a new one if you wish.
I hope this helps you out, and have a nice day!
Mar 31, 2011 | Gateway DA0MA2MB6D8 6000 and M360 Series...
I dont have the bios pasword kav60 luwcx0b0069443f2ea1601
you can disable the Bios password by opening your laptop to view the motherboard, look carefully on the jumper settings, you will identify password jumper setting on your motherboard, remove the jumper on the two pins. by doing so, you have disable the password and can now access your Bios configuration
Sep 24, 2010 | Gateway Computers & Internet
How do i bye pass the bios password in gateway 400VTX laptop
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Apr 07, 2010 | Gateway 400VTX-3501335 Notebook
I GOT A GATEWAY LABTOP AND FORGOT MY PASSWORD
sometimes the admin doesnt have an pasword. do you have vista or xp?
Jan 05, 2010 | Medion MD 96340 Laptop
I have an E210882 Intel based motherboard that I got when I purchased a Gateway computer a while back. I had to swap out the case (custom power supplies Gateway used), but I failed to set the jumpers on my...
If your board has built in sound, the jumpers would be the same no matter what case you put the board in. The wires you pulled off the case are for the LED lights and the computer speaker not the sound.
Aug 14, 2009 | Gateway Computers & Internet
Little clip
is this a clip for holding something in place or a jumper like this one? 5269983d5c31a7ca
http://www.thg.ru/howto/20020904/print.html link if picture does not show ( scroll halfway down to see jumper photo.
if it looks like this , bend the two pins it goes on apart just a tiny bit before you replace it on the pins, this will add enough tension when you put the jumper on to keep it from freely falling offf
May 08, 2009 | Gateway M-6750 Notebook
Gateway (4000444) Motherboard Logo
496 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
