Question about Diamond Multimedia ( VC500) Video Capture
How to set up one-touch video capture vc500
Hello I just purchased the diamond one-touch video capture vc500 and the end that connects to the vcr has s-video and rca connections,, Do I only have to connect the rca cables to the vcr?
  • skippahog Feb 21, 2009
    do i have to buy a s. video cable if i want to record a tv programme with my vc 500?
  • Anonymous Mar 13, 2014
    Just got the vc500 running on Win7. I am attempting to convert vhs to digital using EZgraber to avi. I tried the Mp4 video output but the resolution was lousy. So I coverted avi to mp4 using Handbrake at it was MUCH better. My question is while ripping the vhs with ezgrabber the vhs ends but ezgrabber keeps recording. Does anyone if there is a way autostop ezgrabber capture when the VHS has ended? Many thanks from a noob
You can use either the S-video or the RCA video connector. I don't think you can use both at the same time but I haven't tested that. Also, if you use the S-video adapter, it has no audio so you also have to use the RCA audio connectors when using S-video. Hope that helps...
Posted on Feb 01, 2009
Diamond VC500 no video formats and black screen, not recording
Had this exact same issue, tried uninstalling, reinstalling, unplugging, plugging back in, updating drivers, etc. with no success, but it was all resolved instantly when I switched the device to a different USB port. The port I was using before works fine (in fact my keyboard is now connected to it as I type) but maybe it is a different type of USB port, and not the one the video capture device is looking for. Hope this helps others with the same issue.
Jan 08, 2012 | Diamond Multimedia ( VC500) Video Capture
When I connect my camera up to the one touch video capture card my diamond media the video camera picture flickers. Can you help me? thanks.
I had the same symptoms - black & white flickering image.
The problem was that my video source was PAL (European) but the software was set to NTSC (USA) video signal format. When I changed this, it was normal colour video without flicker.
I happened to be using AVS video recorder but similar settings probably exist in most capture programs.
Mar 28, 2011 | Diamond Multimedia ( VC500) Video Capture
When I connect the VC500 to the computer and the vcr, most times, the video plays fine. When I try to record, the video skips - it records - but skips and the recording skips as well. It's almost as if...
Hello mabusse
The sofware is too heavy for your computer . You can improve it's function buy setting the quality to a lower level , it will record smootherly but of course the image will be less sharp .
I experienced my self that the best way to succeed in recordong video tapes or tv programs is to use a stand alone recorder .
Best regards ,
fanaudi .
Mar 03, 2011 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
Cannot save video from vcr
Save should be continuous and automatic when 'Record's pressed. The file is ended and closed when 'Stop' is pressed. The configuration setup tells where the file is to be stored; if no setup was made, it would most likely be in 'my documents' folder. The files are .mpeg types.
Feb 10, 2010 | Diamond Multimedia ( VC500) Video Capture
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
4,767 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
A Vlad Fuica
Level 1 Expert
Lawrence Oravetz
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
