VBA Macro i m looking for code to find Calculate the Width of the Columns Calculate the Height of the Table in a non uniform table using VBA ..PLS HELP
    Brigadier General:
  • 10,406 Answers
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework assignment.
Posted on Dec 03, 2009
How do you calculate volume?
depends on the shape of the solid. Some regular solid have well established formulas by which to calculate the volume enclosed.
Right rectangular prism volume = length* width*height, etc.
Here are some.
Volume of Solids Reference Table
Sep 26, 2014 | Office Equipment & Supplies
How to calculate cubic feet
Hello friend, thank you for your post!
Typically you can locate the cubic feet by multiplying length, width, and height. If you would like for me to double check the cubic footage of your appliance, could you please provide me with the model number? With that information I can better assist you. I look forward to your response. -Matt
Aug 27, 2014 | Frigidaire Refrigerators
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How do you determine the amount of columns to be used in a web design table?
You need to decide how you want the web page to appear. Most simple web pages have 2 or 3 colums to separate the content. If you are adding images, this may influence the width of a colum. e.g. if an image is 300px wide, then the column should be at least 300px wide. A web page may be set to a size suitable for viewing in browsers, the most common widths being between 600 and 925px. So if a web page is 600px wide, you would only get 2 columns of 300px width, or 3 columns of 200px width.
Nov 10, 2009 | Computers & Internet
How to make macro using the VBA
You can "record" a macro and look at the code or write one yourself. To see code, you'll need to open the VB Editor using <ALT+F11>. You may also enable the "Developer "tab in the Ribbon using the Options dialog and going to the "Popular" tab. From the Developer tab you can access the VB editor. From this tab you can recod a macro too.
Feb 23, 2009 | Microsoft Office Professional 2007 Full...
Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Apr 03, 2008 | Microsoft Office Standard for PC
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Macro through excel
What did you actually want to do with it as Macro VBA coding is rather large?
Oct 26, 2007 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
