Hello i have connected the MAGNAVOX PH-61155 2 X 1 A/v Selector with Built-in Stereo Rf Modinulator into my acer laptop threw a s-video cord and the cable cords but i still recieve no video of the acer laptop, so i was wondering what i should to to see my acer laptop on my t.v.
  • 2,071 Answers
Maybe connection error,try to review the hooked up connection maybe there might be interchange;
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 26, 2008
NES controller input
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Mar 02, 2012 | Nintendo NES Console
How do you hook up the super nintindo console to the tv?
Original-Style Super NES RF to TV Hookup
hook_sns_rftotv.gif Installation Steps:
  1. Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
  2. Disconnect the existing cable wire from the TV's VHF IN.
  3. Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
  4. Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
  5. Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
  6. On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
  3. Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
  4. Slide the Power Switch to the On position.
  5. Turn on the TV and set it to the appropriate channel (3 or 4.)
  6. The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 13, 2012 | Nintendo Super NES Console
Eu tava com o super nintendo ligado e ele espludiu a fonte
Aug 21, 2011 | Nintendo Super NES Console
I have to unplug my vcr to hook up my wii ad want to hook both up so i dont have to unplug and plug all the time. help.
Philips PH-61153 4x1 Automatic Video Selector and RF Modulatorhttp://www.amazon.com/Philips-PH-61153-Automatic-Selector-Modulator/dp/B000165AOY/ref=sr_1_4?ie=UTF8&qid=1310350845&sr=8-4
Plug both into this. Automatically switches to the one powered on. Connects up to 4 audio/video components to a TV or home theater system. Built-in RF modulator works with all TVs including TVs with only coax jack input. Works with composite cables, S-video cables, and coaxial cables. About $25 from Amazon.com
Hope this helps.
Jul 11, 2011 | Video Game Consoles & Games
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Hello
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Can you hook up a super nes without AV cords? I have 2 cords, 1 is power and 1 connects to an antenna-like input.. do you need AV cords aswell??
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
Jul 23, 2010 | Nintendo Super NES Console
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Great video, NO AUDIO
Hello dis2,
Try using the s-video with the audio inputs (Red-White) or the composite video (yellow connector) with the audio inputs (Red-White), if these work then the problem is with your RF connection, this happens at times the modulator that provides the channel 3 signal malfunctions (this is a quality issue).
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 13, 2009 | Philips Magnavox 20MT133S 20" TV
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
 Grubhead
Grubhead
