Afficio 450 programs....
Hi to all .... i nid help i want to format my afficio 450 program... wer can i download the program... and how can i reformat the afficio 450.... bcoz i want to have a new fresh program in my machine... tenkz....
  • 5 more comments
  • thraser
    thraser Sep 02, 2008
    how can i connect the afficio 450 copier in my computer i olridy download the driver size 1.42 MB...what will be the connection i will use...
  • thraser
    yup...der is 3 slot at back telephone connection...?? wat will i do to connect it to my computer??
  • thraser
    thraser Sep 03, 2008
    yup its in the back... my new copier is Gestetner 3245... affcio 450 and Gestetner 3245 is thesame...im ryt... so how can i connect it in my computer what will i nid to do??
  • thraser
    how can i do it... il just put modem to my computer and connect it with my copier thro ethernet cable and instal the software of my copier to my computer... datz all...
  • thraser
    My copier is RJ 11 connector support .... when i will use router to connect or network my copier and computer i will stil nid to convert the RJ11 connector to RJ45 so dat it can be connected in router... is der a router dat RJ11 connector??
  • thraser
    thraser Sep 11, 2008
    hi bubbabear64 i cleane up my machine bcuz ders a lot of toner spiling around the developer unit.. when i turn it on i got error sc 322 1st laser synchrinization signal error...wat will i do hope u can help me tenk a lot
  • thraser
    thraser Sep 26, 2008
    wat is "used toner case is nearly full" wat will i do??
  • 2,794 Answers
You have to have all the firmware in order to able to do that. It comes on a PCMCIA card that you plug into the copier. If you format the hard drive, there will be no way of getting the programs back unless you have that card.
There tough to get but I found a few of the cards on EBAY. Once you get that, then it's a matter of getting a hold of the software (if it isn't on the card already).
Posted on Aug 26, 2008
  • 4 more comments
  • Tim Babcock
    Tim Babcock Sep 02, 2008
    Does your copier have an ethernet connection on it?
  • Tim Babcock
    In the back of the copier is the telephone connection. It should be on the left side of the copier.
  • Tim Babcock
    Tim Babcock Sep 03, 2008
    Just need an ethernet cable and network connection to your gateway.
  • Tim Babcock
    Your going to need a router. Your router will plug into the modem. Your computers and copier will plug into the router.
  • Tim Babcock
    You can only use RJ 45 for networking RJ 11 is fax machine use only.
    If your'e in the Seattle area I'll come out there and hook it up for you.
  • Tim Babcock
    Tim Babcock Sep 11, 2008
    The optics need to be looked at.  It could be anything from a board, cable, to a power supply.
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
Hw many grams dv is needed in afficio 450 or gestetner 3245
I just responded to your other thread, sounds like you are trying to use a generic dev, or something. You are asking for big trouble.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Wer can i get service manual of afficio 450 free
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
The manual is in PDF format, however on the same page is a link to download the free acrobat reader if you don't have it so you can read this manual.
Please rate this solution and thank you for using Fix Ya!
Aug 21, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
95 people viewed this question
k24674
