Question about Dell Latitude D600 Notebook
Help Where is the RAM?? Is it under the flaps? or is it under the screw thing that has the W?
That "w" is actually a M for memory. And yes, that's where it is located.
Posted on Aug 28, 2008
How do i install mud flaps 12wx22h inches on my 2011 ram 1500 thanks in advance
That depends on the design of the mud flaps. Typically they have holes in the top for sheet metal screws. Look for any existing sheet metal screws in the fender wheel behind the wheel that match with the holes in the flaps - you can just remove those, put the mud flap up and put the screw back in if it is long enough (if the mud flap doesn't have a metal strip across the mounting edge, you'll need a large washer under the screw head to distribute stress across the material or it will crack).
If you don't have matching holes, you'll have to drill them. If you are going into steel, use a bit sized for the shank of the sheet metal screw, or just drill the screw in directly. After you get the screw in, take it out and fill the hole with rust-protecting sealant, then put the screw back in. If your mounting hole is on fiberglass or plastic, use a nut and bolt with fender washers under both the screw head and the nut. I recommend either stainless steel or cadmium plated hardware for corrosion protection; this is a harsh environment.
If you don't have a straight surface for mounting the mud flap, you may have to bend a heavy galvanized steel strap with holes in it (perhaps a pipe hanger) to make a mounting bracket. Attach one end to the vehicle as described in the previous paragraph, and attach the mud flap to it.
I would expect a new mud flap set would include the necessary hardware to adapt it to different vehicles. If you've already purchased a new set without any of this material, you can look at some of the other sets on the market for ideas on mounting brackets. The exact method you use is not critical, so long as it holds the flap without breaking anything (consider the stresses from flapping back and forth and try to envision where the greatest stresses and material fatigue would be), and is reasonably protected from corrosion.
Nov 04, 2011 | 2011 Dodge Ram Pickup 1500
Tip
Black or Blank screen fix?
Often I see people say they turn on, lights are on but NO screen. The fix maybe to REMOVE and RE-SEAT the RAM module. Usually it is located under a flap under the Laptop. Remove the flap, take out the SIMM and then replace it. Often this will restore things back to normal. But NOT always.
on Feb 03, 2010 | Computers & Internet
Memory card installer
To install a memory card [RAM] Turn the laptop upside down and you will see some flaps held togather by one screw take out the screw and your Ram sticks will be laid down if you have an empty one you can insert into that port ,it is better to insatll in pairs so if you go to www.crucial.com and run the detector will tell you how much you have and how much you can put into each slot you can buy there Ram there or wright down the ram type and amount and order it from a place of your choosing
Aug 22, 2011 | Acer Computers & Internet
2004 dodge 1500 cabin air filter
the cabin air filter is located on the passenger side of the cowl. after opening the hood, remove the windshield wipers and the black covering ( 2 small T-30 screws, and a few body grommets). after you remove the cowl there will be a grey accordion looking filter in the cowl, remove that and replace with the new filter.
Apr 18, 2011 | 2004 Dodge Ram 1500
I want to upgrade my Advent 4489 Netbook to 1GB or 2 GB RAM. Is there a repair or upgrade manual I can get to help with this upgrade ?
Is easy, just need to open flap under Laptop, buy RAM, Remove Old, and clip in replacement. really not need manual. Just make sure you get correct RAM rest is easy.
Apr 04, 2010 | Computers & Internet
Can a emachines T4010 be upgraded to $GB DDR SDRAM and what slots do I put it in?
According to the manufacturers web site is YES. Under the PC there is a flap, under the Flap are two DIMM Sockets, you put two 2GB RAM modules there.
Mar 13, 2010 | Computers & Internet
HOW TO GET TO THE RAM IN A45-S250
You will find the memory on the Toshiba A45-S250 under the keyboard. Snap of the grill that also has the on/off button on it, just above the keyboard. You will find two screws holding down the keyboard and another screw near the middle holding down a small silver piece that is holding down the center part of the keyboard. Lift the keyboard from the screen end toward you. Memory is located under a clear plastic flap.The power should be off and the battery removed during this operation. Be sure to touch some metal piece to ground yourself also. Good luck.
Jan 06, 2010 | Toshiba Satellite A45-S250 Notebook
2001 dodge ram 2500 diesel - my air conditioning blower is blowing but the air is not coming out of any of the vents
the flap inside the vent is not opening you will have to get under the dash and figure out why the lever isnt opening the flap
Dec 04, 2009 | 2001 Dodge Ram 2500 Truck
RUST ON DOOR UNDER DISPENSER
THE HIDDEN SCREWS UNDER THE DISPENSER TRAY ARE NOT STAINLESS STEEL
ONLY WAY TO SOLVE THIS IS TO KEEP AREA DRY
OR TO REPLACE SCREWS WITH STAINLESS STEEL ONES
May 26, 2009 | Refrigerators
Capresso C-1300 not working
You can re-attach this brown flap youself if machine is not still under warranty (that would void the warranty) or if the tabs or flap is not broken. I have had this machine apart and have taken off the brown flap which have tabs on the top and sides that fits on the front(facing you) of the press (looks like a big white cog inside a brown case( I have photos). The thing is, taking the case off. Screws with special tops that requires specialized tools for removel of case. My husband had to use pliers very carefully to get these out and he said he will put regular same size back in. If you want the manual or photos, let me know yor e-mail.
Feb 03, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Dell Latitude D600 Notebook Logo
14 people viewed this question
Alun Cox
