Question about Samsung SYNC SGH-A707 Cellular Phone
Samsung a707 dropped my Sync in the toilet for 10 seconds. Took off extra skin, removed battery cover, battery, sim and memory chip. Shook as much water out as possible and dried it with hairdryer for a while. Phone works for the most part, but there is moisture under the top cover, inside the front window. and I can see a ghost rectangle in the middle of the inside window, although the window works. I tried to remove the 6 back screws but have only been successful with 5, which did not come out completely, just got loose. Other 1 is reluctant. How do I slide it open when tne last screw is loose? Do the screws need to be removed completely? As for the front cover, I removed the two screws i could see near the camera's backside but cannot figure out how to open slip off the cover. Can you help on front or back or both? Lisa
    Scholar:
  • 87 Answers
Sorry for the delay in response...
Once you have the screws loose, they sometimes stay in the housing. That is okay as long as they are loose from the mounts. The top half only has the two screws. Once they are removed, work the seem with an opening tool, or strong fingernails. Gently pry open the seem and it will start to pop apart. Be careful in the top half because the flex for the surface buttons is attached to the outer housing or front cover. Once you have it snapped loose, you have to unplug that flex, so be careful not to tear it.
Once you have the phone apart, brush all components (not the screen) with 91% rubbing alcohol and a soft bristle brush.
If you want, you can also try leaving the phone in a bag of dry rice. That tends to wick out moisture quite well.
The only risk there is that once moisture is in a phone, it tends to start corroding. It can work fine for quite some time, and then have problems later so I recommend disassemble and clean if at all possible.
Posted on Aug 28, 2008
  • Chris Havens
    Chris Havens Aug 28, 2008
    Also, use the hair dryer to dry alcohol out under chipsets before reassemble, because it takes longer to evaporate under there.
Samsung sync hardlock
your sim chip totally damage. change sim or" number.
May 28, 2012 | Samsung SYNC SGH-A707 Cellular Phone
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
Jul 18, 2011 | Samsung SYNC SGH-A707 Cellular Phone
I dropped my cell phone in the water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 08, 2009 | Motorola Mobility RAZR V3
SGH a707
well u did a mistake.........u should'nt turn on the phone for a day or two............but its not a big one..........takeout the battery,remove the cover n sim........let it be off for a day or two...it should work properly if still problem exists change the battery........
Oct 07, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Red Screen/Download
if you have warranty for that phone you better take it back to the store you baught it from. it can be a very big danger hazzord if you dont
Aug 17, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SIM card issues!
you dont have to buy new sim...go to your nearest service senter. hardware failure.... sim sockets or sim ic... thats the problem...
Apr 08, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung Sync Red Battery Cover
if you've tried stores like radio shack, call the company or a parts provider...
i know..common sense and you could've figured that one out...ha.
Nov 20, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Cell phone water logged
hi ive had alot of people ask me this question they tend to drop theres when there on hol and cum back crying to me wot u want to do is buy some distilled water take ur batt out and sim and memory card and take ur case off put it in distilled water for 5 mins take it out and dab it dry this sounds stupid but get sum WD-40 and spray inside ur fone this helps to dispell all the water thats trapped inside and leave it under a lamp with a 60watt bulb on it fo9r 3 to 4days sumtimes it could take a week try that
Aug 12, 2007 | Samsung SYNC SGH-A707 Cellular Phone
My Samsung SYNC got a little wet. Now it just says "download" on the display.
Follow these steps to get out of this problem......
  1. Takeout the battery.
  2. Leave your phone in free air for a day or two with back cover and battery removed along with Sim card.
  3. Put the battery back in phone and see if it works,else buy a new battery and follow above steps again before putting new battery in phone.
Thank you...!
Aug 02, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
110 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
