Question about Pioneer VSX-815-K Receiver
VSX-D814 no power
I cant get the reciever to power on. no standby led or relay click when i apply 120v. I seen that another person had the same issue. i have tried to troubleshoot the power supply circuitry, but without the schematics, well its a **** shoot. Any help would be greatly appreciated.
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
petraman7
  • 1175 Answers
SOURCE: VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Posted on Feb 08, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
Joelpogi
SOURCE: i have a pioneer vsx-501. I can't get it to turn
have you fixed it already?
I have the same receiver with the same problem as yours.
I found the fault in the voltage selector rotary switch. I'm refering to the round voltage selector switch not the other one, because you'll notice that there are 2 voltage selector switches at the back. The lock was broken so it couldn't switch the primary terminals of the main transformer.
Basically this amp has 2 power transformer, the small standby traffo and the large main traffo.
Try to press that round switch and press the front panel power switch. If it goes ON, then fix the center lock of that round switch.
Hope it helps.
Joel Herrera
Philippines
Posted on Nov 19, 2009
  • 5 Answers
SOURCE: I have a pioneer dvd
LAZA got a haircut .
Posted on Dec 21, 2009
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
Mar 16, 2011 | Pioneer VSX-515 Receiver
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby button......is this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad ..to confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer EliteĀ® VSX-01TXH 7.1 Channels...
Pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Standby light on pioneer vsx-d308 receiver
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
Pioneer VSX-815-K Receiver Logo
61 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
