Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Condenser fan motor
Hi I have an amana MDL# SXD22S2L MFG# P1303503WL while the condenser is runnig I noticed the fan not moving when I spun the fan blade by hand the fan starts working again for a few cycles then later I notice it not moving spin it and whola it works again for a few cycles. my question is is it the motor, Capacitor or main board ??? How can i test to find out which.
  • Fix-R-Up Jan 01, 2009
    I have the same issue with my Amana fan motor. I also have the heat issue posted earlier. I believe they are related in root cause, i.e. low voltage to fire cap so motor can start etc.
    Did anyone ever solve this issue for you?
  • 62 Answers
Technically, you could take the wires off the motor and check to see if you have 120 volts which elimenates any other componet. The fact that you can spin the motor and it runs some what indicates that you do have the voltage there and that the bearings in the motor are going bad and causingthe motor to stop. Repalce the motor,
Posted on Aug 31, 2008
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams or . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at anytime.
Apr 09, 2013 | Amana Refrigerators
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
My Amana bottom freezer model # BB20VSE, serial # 0006289684, mfg # P1321301WS has become increasingly noisy when the compressor(?) turns on. This started over a year ago and now is extremely loud. Thank...
Ah this is an indication that your condenser has become dirty, or blocked, or the fan motor is not working or the air flow is restricted.
The noise is generated when the compressor cycles off and sudders to a stop
Mar 24, 2011 | Amana ARB9058CS Bottom Freezer...
Our Amana fridge freezer has stopped chilling and freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Jun 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Condenser fan inop
genarrly the fan motor runs in conjunction with the compressor assy, ifhte compressors not runnig you wont get hte fan to run either. is the compressor running??? if so check the wiring between the 2 components
Mar 23, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
489 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
