Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
DeLonghi portable airconditioner leaking water
My DeLonghi portable airconditioner bought 3 weeks ago is leaking water under the unit.We tried to drain all water according to the manual but it did not help the problem.Any help to resolve this problem will be greatly appreciated.
  • 750 Answers
Nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
Tip
How to stop portable air conditioner leaking water
I heard that some portable air conditioners can leak water from the unit after being operated for about an hour or so if they are not on a level floor. <br /> I solved this with my DeLonghi air con after discovering the floor my unit was on had about 1 - 2 mm difference from one side to the other. By buying a small builder's liquid level (like you use to keep a line of bricks aligned) I used a small piece of wood (ruler thickness) under one side of the air con and no more leaks! Hope this helps someone. Kez, Perth WA
on Jan 30, 2011 | Heating & Cooling
Hi I'm bill I just to want to ask something regarding about my delonghi ariagel ag75 7,500 BTU/h.its a portable conditioner with 3 modes.And ive been using this for almost a year now.And wasn't...
Hi Bill, I also have a Delonghi portable air-con, so I hope I can help. Is the machine working ok apart from the leak? Does it have a built in waste water tank as does mine? If so, take a look at where the tank is placed to empty the machine, it is possible that the pipe leading to it from the machine is out of position and instead of filling the tank with water, it is dripping on the floor instead. If you remove the water tank, the machine will not run on air-con, but if you have a look at where the tank fits in (you will need a torch) you should be able to see where the water is coming from.
These machines do create a lot of waste water, that is normal, but it should end up in the water tank, not on the floor, so you need to find out why it is not reaching the tank.
As to your problem with the manual, I have found these links for, Delonghi so that you can contact them directly and explain that you need a replacement. As I don't know what country you are in, I have put a few for you to try, they should forward the query, or refer you on.Hopefully, they will either email you with a copy, or they might post a replacement. Good luck!
http://www.delonghi.com/uk_en/agency/
http://www.delonghi.com/us_en/agency/
http://www.delonghi.com/au_en/agency/
Aug 21, 2011 | DeLonghi Heating & Cooling
Delonghi Pinguino K900, continued to blow hot air, what should be the solution. I want to enjoy the airconditioner aspect of the unit.
There a several things that can cause the problem you have described.
1. The Dehumidifier Mode is operating at the same time as the AC or is operation on it's on.
In dehumidifier Mode heat is produced.
2. Air filter needs to be removed and cleaned.
3. A blockage or crimp in the exhaust hose.
4. The exhaust has a leak or has come loose from the unit.
5. The unit is sitting in direct sunlight or is adjacent to a heat producing appliance.
6. Compressor needs to be recharged with R134a refrigerant gas.
The 6 things listed above are where you need to start troubleshooting. 5 of which are easy to check and correct.
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | DeLonghi Pinguino PACL90 Portable Air...
Buckets of water leaking but the reservoir is dry!!!!
If you have cleaned the air filters then that is the first step. Next you want to check the condenser coil. That is the coil that is outside. If it is dirty you will have a low charge situation which could cause lots of condensation. Also if the condenser coil on the outside is clean and you are getting lots of water than you my have low charge of refridgerant. If that is the case you will need a professional to come and charge the unit and find the leak. Did you check to see that the unit is level. Because is should drain to the outside. The unit should be installed in a way that the water drains to the outside.
Aug 23, 2009 | DeLonghi CF210 Portable Air Conditioner
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PACL90 MODEL
For a short time you can run without filters. I suspect it is low on charge or the metering devise is not working. Check this link out for an owners manual. It may help you.
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Aug 17, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
1,890 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
