Question about GE Energy Star WCVH6260F Front Load Washer
GE front load washer can't handle more than a single shirt at a time or won't tumble or spin
I have a 2 year old GE front load washer that will not tumble or spin with more than a single item in it. I ran the trouble codes and found 42 & 4B, both said to replace motor. I replaced the motor and it did not change anything...same problem. Ran through all the test code sequences and when empty all check-out good, but put a single towel in the tub and it will start to tumble or spin but thin just shakes for a moment and stops, tries to go the other direction and may make it around one revolution and then same thing again. Could this be the 3-phase inverter?
    Novelist:
  • 166 Answers
Front load washers have an auto water level determined by the weight of the clothes placed in the washer.
If that sensor is malfunctioning the washer may not run !
Unfortunately I think that its time to spend $75. and have a trained GE laundry tech with hands on diagnostic experience remedy the problem. Rather than you spending tons of your hard earned money swapping parts!
I agree with you on that point!
I understand this is not as complicated as a jet engine.
And you tried your best,but some times it is more
cost efficient to let a surgeon fix my hernia while I'm relaxed and under anesthesia, than try to fix it myself!
If My jet was broken, I would not risk flying it after I fixed the problem because I am an appliance man!
I would prefer my life in your hands with your expertise !
Please cut your self a break and call service. You may find it interesting, and fascinating yourself to see what the problem was!
Bless you, and let me know what was the end result!
I believe if I was there with hands on, I would solve your problem!
Please give me a good rating before you sign off, for my rational and calming advice
ngafm
Posted on Sep 08, 2008
Washer won't spin. 2 years old.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Kitchen Ranges
I have a LG WM1814CW front load washer. I get UE when it trys to go on spin cycle. I re-arranged the load and still comes up UE. I also tried a cycle without anything in the washer and still the same...
The UE error code is nothing to worry about. It indicates an "unbalanced error"¬-your washer's way of saying that the drum is not spinning is a smooth rotation. It could be as simple as rearranging the load in the drum (click image for zoom). Here's why:
1) Small loads. Your washer operates better when the weight of the load is evenly distributed across the drum, but that is not always possible with small loads.
2) Mixed fabric loads. For example, if you're washing jeans and t-shirts, the jeans could be on one side and the t-shirts on the other, causing the unbalance. Try rearranging the items and spin again.
3) Large single items. Items like sheets, blankets and comforters tend not to spread out evenly, causing unbalance when the drum spins. Rearrange the item and start the spin cycle over.
4) Spin Sense Option. If your washer has the Spin Sense Option, it may try to adjust the load on its own. If that happens, the washer would slow down and tumble a few times slowly during the spin cycle and then speed up until the problem is resolved.
Hope this helps.
Jun 24, 2011 | LG WM-2077C Front Load Washer
My ge washer wssh300g1ww does not spin out clothes well
Hello, I too bought one of these washers(WSSH300G1WW). After about one year of operation i noticed that the low spin cycle was making noise so look at it and it was just making noise and not spinning. canceled the cycle restarted the machine but this time set the spin speed to high instead of low, it works on high. im guessing its the clutch in the machine that is faulty and really cant affoard to fix at this time. The thing is i liked to use low spin cause the thing would shake violently on high even with a small load. So now when it spins or i start the machine i make sure theres nothing close that its shaking will cause to fall and break. I also bought the matching dryer (dsxh47eg1ww) it too has problems, the bearings that hold the front of the drum up are going out, thing is i dont over load it and it seems that they went out or started to go out very early as my clothes were getting caught inbetween the drum and the dryer 2 months after i bought it. Im 42 years old so i remember when we had REAL washer and dryers. When quality was revered by companies and consumers. Those old machines ran for years (maybe even decades) without problems, replace a belt from time to time. Now days your lucky to get five years out of an appliance. I know these ones arent going to see 5 years. their about 2 years old and im ready to go find some 1970 model year washer and dryer, rebuild, give a custom paint job to call them retro.
Jan 22, 2010 | General Electric WSSH300G Front Load...
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
I am getting an error code "DC". What does that mean?
DC means: Unbalanced load prevented the washer from
spinning.
This happened to me when i was washing a single shirt (red shirt, first time washing so i did it seperately so it wouldnt bleed into other clothes)
So i set the washer to "drain", waited for the door to open, and wrung the shirt out by hand. Next load it worked properly.
Jan 16, 2009 | Maytag Neptune MAH9700 Front Load Washer
Reseting of spin / wash cycle
dont know how old, but get those techs back to fix ,call their boss ,call GE and complain
Dec 31, 2008 | GE WCVH6260F Front Load Washer
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
100 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
