Question about Dell Inspiron 5160 Notebook
Power on immediately powers off
Not sure what the heat sink is and that might be my problem. Because when I took out the fan assembly, the CPU came with it. I didn't try to separate the two. I assume they shouldn't be one unit. Should they come apart easily?
  • Dell Master
  • 3,051 Answers
Yes it should there should be some white greese looking substance that is between the two and it is necessary to transfer the heat without it the laptop sill do that
Posted on Aug 26, 2008
  • Michael Thomas
    Michael Thomas Aug 27, 2008
    just wondering have you gotten anywhere with that yet please keep me posted ok best regards mike
    a
Power supply was shuting down after a while and now it will only power up for a few seconds. If i unplug the power cord for about 5-10 minutes system will come on for about 5-10 seconds.
This may be a bad power supply or an overheating problem. be sure the cpu cooling fan is spinning and you don't get, possibly, a siren tone from the computer (usual warning of over heating) Make sure the heat sink cooling fins aren't clogged with dust and that the heat sink is attached to the CPU correctly. sometimes a clip breaks and the sink loses contact with the chip. if this happens, the chip will overheat almost immediately.
good luck
Feb 12, 2014 | HEWLETT-PACKARD Pavilion Slimline Desktop...
My laptop powers on and right back off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 26, 2013 | E-Machines Computers & Internet
Power problem
Dec 12, 2012 | Toshiba Computers & Internet
MY SAMSUNG P35 LAPTOP STOP ITSELF ON BATERY AND AC POWER
This maybe heat problem.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 27, 2012 | Samsung P35 HZM (NP35TP0FL2/SUK) PC...
Power supply has shutdown
It may not be the power supply.
Mar 06, 2012 | Computers & Internet
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Computer shuts down by itself
There can be many reasons of unexpected shut down of your system.Below are some remedies to solve it
Run an anti-spy ware and anti-virus utility to make sure that the shutdowns aren't being caused by a malicious program. If the shutdowns are infrequent, install a CPU temperature monitor utility to keep track of the CPU's temperature. If the CPU is overheating, or the shutdowns are frequent, then you will need to troubleshoot your computer's internal components.
Check any recently installed internal components to ensure that they are properly connected to the computer's motherboard. Make sure any new expansion cards or memory modules are securely seated in their slots, and ensure that the power and data cables are properly connected to any new drives.
Check for large dust buildups on your CPU fan. If the fan isn't effectively cooling your CPU, the overheating CPU will cause your computer to power off. Carefully pick away large pieces of dust with your fingers, and then spray the CPU fan with a can of compressed air to remove the rest of the dust.
Reapply the heat sink compound between the CPU and heat sink if the computer continues to turn off unexpectedly. Heat sink compound is a pasty substance that fills the space between the heat sink and processor, which increases the heat sink's ability to absorb heat from the CPU. But worn heat sink compound won't properly redirect heat away from the CPU. Power down your computer, disconnect its power cables and open the case. Unplug the CPU fan's power cable from the motherboard, remove the heat sink and fan combination from the CPU, and then apply the heat sink compound to the CPU--refer to your product manuals for details on reapplying heat sink compound.
Thanks .
Have a great day.
Oct 03, 2010 | Dell Inspiron 537s PC Desktop
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
have you checked the the heat sink that is installed beteween the processor and the cooling assy if there is too little it will do that
Aug 25, 2008 | Dell Inspiron 5160 Notebook
Wont start up
my wife has a presario that had a similar problem - it would boot up, then immediately shut down. I took off the side plate and blew off some of the dust inside. that worked for a couple of days then the symptoms returned. I took it apart again but this time I removed the cpu fan and the cpu heat sink. I cleaned all the **** off the fan and the heat sink and replaced it. this time it stayed on. I checked out the power supply. compaq installed a very cheap power supply - only 250 watts. a replacement power supply for the same machine but with an output of 300 watts is available. as soon as I can scrape up the change, I'm gonna change the PS
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Dell Inspiron 5160 Notebook Logo
37 people viewed this question
Alun Cox
