My dynaglo propane heater runs about 15 minuets then cuts out.
    Champion:
  • 254 Answers
This sounds to me like the operating thermostat is going open prematurley. Check the sensing bulb end to ensure that it is not out of place and touching a heat riser. If this is not the case most likley you will need to replace the operating thermostat.
Thanks
Zerko
Posted on Aug 30, 2008
Heater will fire up, but only run for about five minuetes. i changed the pressure switch and fuseable link. no change. turned off power to reboot. came back on for about a minuete then went back off.not...
Possibly poor water flow. Clean all the baskets, pump too and backwash/clean the filter. If water flow is ok it might be the temperature control. If you are running it on "pool" try using the "spa" control...
Jul 19, 2010 | Pentair Minimax NT Heater
I was given a purex/triton 400 pool heater
It will not work more than a few minuets. The small tank will not contain enough volume required for the liquid propane to boil off the amount of vapor you need to feed the heater. In fact you are more likely to damage the heater if it does run because it will be a very lean burn.
Aug 14, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
Need a replacement thermocouple for my DynaGlo Pro job site heater. Propane fueled, model RMC-FA4ODGP. Any suggestions ?
All thremocouples have a number on them which tells what 'millivolt' output it has. Try to match that up or call a HVAC company and ask them for one with that number.
Oct 05, 2009 | Heating & Cooling
Smokes up ceiling above heater and in room
sounds like it is dirt in burner causing air to fuel mixture problem needs to be serviced
Sep 04, 2009 | Dyna-Glo Heating & Cooling
Stops running after 2 minuets
Honda engines have an oil sensor that sometimes fails. It will cause this. If the sensor fails it is like not having enough oil and will kill the engine for protection. Just something to look into. Hope this helps
May 01, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Propane heater cuts on and off.
Running propane through a gas heater is dangerous and will ruin the heater!
Dec 28, 2008 | Heating & Cooling
Have a dynaglo portable propane heater, it will light, but after a few minutes it sputters and stops working. it will relight but does the same again. dan
You will have to take out the fuel line to get to the filter or clean out the port at the carbuerator. It sounds like the fuel flow is not ample enough to continue burning
Sep 27, 2008 | Heating & Cooling
Dynaglow parts
RobinRents.com carries Dynaglo parts. I'm not sure if they have all Dynaglo parts, though. Give them a call. Maybe they can help. Those foreign made heaters are hard to get parts for, compared to Desa, anyway.
Sep 05, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
