Question about Canon DR 2080C Path-Through Scanner
Incompatible with Vista 64-bit
This post to tell you about my mistakes. I love this scanner, used it a lot, then changed to a Vista 64-bit system and nothing works.
Canon offers three upgrade downloads. One (2080FIRMWARE.exe) is simply to check if you purchased version 3.0 of the CapturePerfect software ($100!). I actually paid for it, installed the other two driver upgrades and... still does not work. The scanner does not appear on the list. Now, it's as good as garbage and I am angry.
  • 2 more comments
  • Anonymous Jan 03, 2009
    same problem. i find it hard to grasp how Cannon can obsolete a relatively high end consumer scanner by just failing to provide 64bit drivers.
  • Anonymous Mar 21, 2009
    Dittos on the problem!
    Canon is going cheap by not putting out drivers & software to work with new computers. 64 bit systems is only the start of the newer systems in the works to be released to the public... Perhaps if enough people complain they will get off their lazy back sides and start to work on a fix for us...
  • Anonymous Mar 22, 2009
    Ditto Here need Vista 64 driver for DR2080C Canon is not providing 64 bit drivers for any of their products. Stay away from Canon>>>
  • Anonymous May 12, 2009
    I have Vista 64 Bit and I use the scanner from Acrobat and it appears to work ok except it seams my scanner may be a bit off. It doesn't scan multiple pages at once well,(gets jammed alot) and has black margins on each side of the scanned pages. Is there a way to adjust the scanner? or does it require cleaning, repair, etc?
    Problem Solver:
  • 7 Answers
The 64-bit Vista driver can be downloaded via Canon Japanese site: http://download.canon.jp/pub/driver/dr/dr2080c_drv23.exe.
But I can't find a free way to upgrade Capture Perfect 2.3 to 64 bit. I may have to use a virtual machine to scan, which is pain in the neck. If you have success with this driver and Capture Perfect 3.0 on a 64-bit OS, please report back. Thanks.
Posted on Apr 20, 2010
Eine Lösung die geht ist ein 2. kleinPC mit winXP32 den über Remotedesktop anbinden. Das ist komfortabel und funktioniert garantiert immer.
Posted on Aug 28, 2009
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Cant install aio esp printrt says its above 32
Contact Kodak support @ 1800 421 6699 and they will change some settings on your system. Kodak printers work only on 32 bits and 64 bits vista.
Jul 31, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon lide scanner vista 64 drivers
This is the link to the drivers and CanoScan Toolbox.
Click on the
Drivers & Downloads on this page then choose Vista(64) as your OS
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=235&modelid=6623#DownloadDetailAct
Apr 11, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Incompatability between hp scanjet 3970 and Windows
Hi, just go to HP drivers and solutions, i have Vista 64 bits.
Rgds, Auke.
Mar 20, 2009 | HP scanjet 3970 digital flatbed scanner
Scanner does not work in Windows Vista 64 bits
Not sure what model of scanner you are using, however, this driver covers Vista 64 bits
http://driverscollection.com/?file_cid=40182882036bd7496c8eedfb446
Nov 06, 2008 | Computers & Internet
Windows vista 64 bit driver
Hi mtrump1,
Thanks for your posting in FixYa.
The driver are available on the Canon Website, use this link to get it:
http://software.canon-europe.com/products/0000441.asp
or
For Vista 64 Bit you can try:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/CANON/Canon-CanoScan-D1230U-611c.shtml
But i think both should be compatible to run in any 32 or 64 bit environment.
Regards
ELLIN
Sep 20, 2008 | Canon CanoScan D1230U Flatbed Scanner
Hewlet Packard Scanner on XP
absolutely not, (MS) it could be for many reasons like incompatible drivers, incompatible OS, mind you if you can double check the right OS platform you have downloaded and the right bit as well, (32 or 64), XP or Vista, can you double check pls, these are some reson why it become too slow
you might want to check on uninstalling this again
Jul 28, 2008 | Office Equipment & Supplies
Open Questions:
See all Canon DR 2080C Path-Through Scanner Questions
Canon DR 2080C Path-Through Scanner Logo
1,046 people viewed this question
old marine
old marine
