Question about Magellan GPS
Magellan Maestro 3250 wont power from car charger. Get message screen that says unit is connected to computer via usb port, and to see instructions in computer program. Will not let you back out of that screen. Unit will charge, but not operate using the car charger. Have tried other chargers with same results. What gives?
Hi, as I have been in the situtaion with many electronic devices before I know how frustraing it can be when the car charger doesn't work any more. For every one out there reading this post if this happen to you again take the car charger portion that you put in the lighter for a charge, the part the goes in will unscrew, check the fuse. 99% of the time that fuse has blown and that is the cause of the unit not getting a charge, if replacing the fuse does not work the it is a bad unit and you will have to get another gps.
Posted on Mar 18, 2010
Does magellan lose its map if battery gos dead
hi etranchina,
no, you wont loose your maps if your battery goes dead. if you loose your maps, you have other issues. correct me if im wrong, but doesnt your 3250 have a map card. i would suggest backing up your maps on to your computer, if there still there...i always back up every gps i get.
are you concerned your battery is going dead, if so, why? that unit is know to develope a bad connection in the usb port (your power port)
let me know if you need further help
bill
Dec 31, 2010 | Magellan Maestro 3250 GPS
Magellan Maestro GPS #MM3225. Screen display this
The unit is now connected to your computer, and you can actually access its filesystem through windows. It is also charging the battery in the unit. I wouldn't want to mess around with the files, though, unless you know absolutely what you are doing. Plus, it's also a good idea to turn the unit off before removing it from the computer.
Apr 18, 2010 | Magellan Maestro 3140 GPS Devices
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
or buy the port here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3250 Stuck on Magellan Screen at Start Up
go HERE, he/i will tell you how you can get it repaired free. this can be fixed but it requires a lot of time and patients..
i dont think there is enough space here to explain fully how to restore the gps....you cant make it any worst but why waste your time if you can get it done for free.
Aug 31, 2009 | Magellan Maestro 3250 GPS
Maestro 3250 will not boot past magellan screen.
When I talked with Magellan tech support they told me the GPS would not be recognized until the unit was sent in to be repaired. The screen was frozen on the start up screen. When asked how much it would cost, they said they had a customer loyalty program and would sell me a new GPS or a refurbished one if I sent in my old one. They could not just repair mine. The cost was more than a new unit on e-bay. No more Magellan products for me.
Aug 09, 2009 | Magellan Maestro 3250 GPS
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Dec 03, 2008 | Magellan Maestro 4250 GPS
Maestro 3250 Charging
I accidentally ran into this problem today when I inadvertantly plugged the wrong charger into the unit. I'm guessing that the device isn't getting the precise current it's expecting and thus thinks it's plugged into a computer. I'd suggest getting hold of a different charger and see if the problem goes away.
Jan 31, 2008 | Magellan Maestro 4040 GPS Receiver
GPS Logo
347 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
