Question about Polyview V17E 17" LCD Flat Panel Monitor
V396 high em waves
We have a v396 until 1 put a wireless router on to run a second laptop i did not realise that the em waves were so bad. it interferes with the router and uhr hand held radios. can any one shed some light?
  • grubby1 Sep 03, 2008
    v396 is the model of the polyview monitor.
Your v396 is suppose to meet federal emission standards. The interference I believe is coming from the back-lighting circuity - it uses high voltage to operate the CCFL's. You can try moving the Wireless router further away from the Polyview V396 to reduce the effects of the V396. You can totally encase the V396 in a metal box to reduce it's emissions but that doesn't really help your situation. You might try contacting the Manufacturer and reporting the problem. They may have a alternate solution.
Posted on Sep 04, 2008
  • 37 Answers
Whats a v396?
Posted on Aug 26, 2008
Can I Put my Lynksis Wireless-G 2.4 in my Laptop? Also does anyone know how to fix the back light in this computer?
Routers do not operate on the same frequencies as the old tv bands. So no. To the other questions you won't put a router in a laptop you would use a wireless adapter which 99% of laptops already have. Last question if the back light is out it is most likely the inverter board is bad. These run $40-120 and are fairly high degree of difficult to replace.
May 30, 2012 | Linksys Wireless-G WRT54G Router
Forgot password and misplaced cd and pass key. Need wirelsess for my laptop.
Reset the router to its "factory" settings, including default ID/password, and then reconfigure the wireless adapter inside the router.
To reset:
* turn the router off
* straighten one end of a Norwegian paper-clip
* insert it into the small hole in the back of the router, until you feel resistance
* push it another 2 mm (1/10 inch) against the resistance, and hold for 30 seconds
* remove the paper-clip
* turn the router on
Connect an Ethernet cable from one of the LAN ports on the router to the network port on your Windows PC. Then:
* Click Start
* Click Run
* Type CMD
* Press Enter
* Type IPCONFIG
* Press Enter
* Look for output like: Default Gateway ..... 192.168.123.456
* Start Internet Explorer
* Type http://192.168.123.456
* Login to the router
* Run the Wireless Networking Setup Wizard, to set:
* SSID
* encryption level (hint: WPA)
* password
Disconnect the Ethernet cable.
Click "View Available Wireless Networks".
Connect to your newly-defined network.
Feb 05, 2011 | Belkin My Essential (ME1004-R) Wireless...
My Dell laptop does not connect easily to d-link WBR 2310 router
2 wireless laptops are connecting. that means the router must be working properly. Only 1 laptop is not connecting.
Try to change the wireless channel on the router.
For this you will need to open the set up page of the router.
Is there any computer connected to the router ? If not then you will need to connect the computer to the router and open the set up page. Under wireless settings try to change the wireless channel on the router and see if that works.
Apr 16, 2010 | D-Link Computers & Internet
Hughes net hn9000 I lose connection when I try accessing Inter.
Try to upgrade the firmware of the router.
After upgrading the firmware, reset the router and reconfigure the router.
Click Here for more info
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router will not go wireless. all lights come on
The "wireless" (second) light on this model does not indicate that the router's wireless features are active, it indicates that a computer is connected to the router wirelessly. If the "router" (fourth) light shows three little "radio wave" symbols, the router's wireless capability is on.
Nov 18, 2009 | Belkin (F5D8231-4) Wireless Router...
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
I have 2 laptops. One my my laptops (Inspiron 2200 Dell running on Windows XP home edition ) was working well until suddenly it would not connect to wireless internet. I am currently on my second laptop...
on your inspiron 2200...
1) click "start", "run", and type "services.msc"
2) select "wireless zero" at the bottom and check if it set to "automatic"
3) make sure that "wireless zero" is set to "start"
4) turn on inspiron 2200 wireless switch
5) right click wireless icon near to your computer's system time
6) click "view available wireless networks"
7) check if your wireless name is visible
Dec 05, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless not working
Yes, There could be alot of things that are causing your Operating System to not obtain signal from your Wireless Router....I would first of all try troubleshooting this by;;
1st - Unplug your High-Speed Internet Modem and Wireless Router for 30 seconds apprx.
2nd - Restart your Computer.
3rd - Once your computer is logged in and at desktop, Plug-In your High-Speed Modem then wait until all lights appear that show your Modem is online then plug-in your Wireless Router then wait about 30 seconds then try to connect to your Wireless Connection.
If these do not work make sure that, you do not have your Wireless Router. I would also recommend that a way to create and obtain a signal strength that the computer can reach please go to the following website http://www.mythings.com/tips/1664/Where-to-Put-Your-Wireless-Router This should assist you with making a stronger signal strength.
Oct 25, 2008 | Computers & Internet
Cannot connect my wifi laptop to the wireless router
If you use your original Win XP disks, there's a chance you now have XP SP1 (Service Pack 1). Make sure you've made all the necessary Windows Updates as working with WiFi networks was enhanced with XP SP2. Then you can try to find your wireless network and connect to it. If you had a secured network you'll need your previous network key (similar to a password, but without a username, the wireless key is needed to exchange data with the router) If you can't remember the settings on your Linksys you can reset it to factory settings with inserting something into the reset hole to press the hidden buton and holding it for several seconds until lights on the front flash. Then you HAVE to run the initial install procedure (find your CD and Quick Start sheet) because your router will be open and unsecured.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Polyview V17E 17" LCD Flat Panel Monitor Logo
96 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
