Question about Cell Phones
I have a conistent RED light on the left side of my phone, right under the E button. What do I do?
    Brigadier General:
  • 7,752 Answers
You have an erom error and will need to have the phone reflash
Posted on Aug 26, 2008
I have a 1994 geo metro. The headlights went out. I checked the fuses. They were ok. The ground wire in the under dash fuse box looked discolored. I made a ground and the left side head light came on...
On these cars the headlights get power from a right and left fuse and the headlight / dimmer switches provide the ground circuit. Both headlights are connected to one ground wire for high and one for low beam. So if one works and the other does not, the problem should be in the wiring before the headlight switch. Red is for high beam and red-white is for low beam. You should be able to jumper the red-white wire on the right headlight and make the low beam circuit for both sides work to test it.
Jan 22, 2014 | Geo Cars & Trucks
Nuvelli NUV2882 Stereo Bluetooth Headphone User Manual
There's no manual available, but if you want to pair your headphones with a computer or a phone follow this steps:
1.- Fully charge headphones (leds turn from red to steady blue
2.- Press for 8 seconds the lower button on the right (it has a phone symbol)
pressing the "phone" button will turn on the headphones, but if you keep pressing it will force the device to go to " Pair mode" you call tell is ready by noticing the LEDs turning blue and red. onces pairing is successful you will see a steady blue LED.
Apr 04, 2012 | Radio Communications
How do I set the time?
For a complete manual visit my tips and tricks page.
The time is under: Settings>Watch
To access settings push either of the right side buttons from the main default screen
Push the red button
use the right buttons again to scroll to watch
Push the red button
Right buttons again to choose time
Push red button
The Right side buttons scroll through choices, the red button is your chooser/ confirmation button. The left side bottom button will return you to a previous screen.
All other settings can be changed in the same way.
Dec 09, 2010 | Polar S150 Heart Rate Monitor
How to program store number in the KXT7730
Under any system, you can always press PROGRAM + a button, dial a sequence and press STORE. What number are you dialing?
If it's an outside number, then the sequence is generally 29 on the left side or 9 on the right side buttons. If inside, then 1+ext on left and ext on right. The left side buttons have lights and will monitor extensions.
Carl
Nov 29, 2010 | Panasonic KX-T7730 Corded Phone
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
How do I program the speed dial buttons? thanks
A 7730 phone has 24 buttons. The left side buttons are CO buttons with lights, the right side are Personal Feature buttons. To program the buttons on the right side, you press PROGRAM, the button, and dial 9-and the number then STORE. The left side buttons require a "2" first.
Carl
Oct 22, 2009 | Panasonic KX-T7730 Corded Phone
I an trying to use the voice recorder on my iHP-120
Press and hold button on left side with red dot (record)... You will see "stand by"...  Press the lowest button on right side (A-B) over and over until "source" is "int Mic"... when you are ready to record, press the left button w/ the red dot short and quick... recording will begin.  When youre ready to stop recording, press middle button (pic of square on it) on right side... that will stop it.
To find your recording, look in the "record" folder under "Audio"
Mar 10, 2009 | iRiver iHP-120 MP3 Player
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
Backlight on Treo 755p
Mine looks the same way.
I think there's a single LED centered between the two buttons on each side of the 4-way. Try turning the lights on and looking at the buttons at a low angle form each side to see what I mean.
Yeah, you're wanting perfection from technology, and technology is =always= a compromise. A.M.
Jan 11, 2008 | Palm Treo 755p Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
