Question about Fuji FinePix 2600 Zoom Digital Camera
Fuji/USB Hi folks, Could any of you folk tell me if the Fuji cam will talk to Windows95 via the USB cable direct from the camera, or do I need to download via a card reader? Some chain stores say it will others say it will not! Many thanks.
    Master:
  • 425 Answers
In general W'95 does not support USB. Only some OEM W '95 versions do support USB, support comes from the computer maker in that case. Since the card reader with W '95 should be the serial type Floppy Disk Adapter of PC Card adapter with PC Card slot is a better alternative. ( Upgrading to '98 would work fine also !)
Posted on Sep 04, 2005
    Master:
  • 425 Answers
I don't think Win95 supports USB; you'd ahvet o upgrade to Win98 or WinME, or get a card reader.
SOURCE:
How do I connect tablet to my computer?
Unless your tablet and PC have bluetooth and can pair up together, this can sometimes be an issue. Folks think that since their tablet is wireless and connects to their home network, they should be able to access it from other PCs/devices on the network. Unfortunately, although tablets are computing devices, they are not computers in the same definition as PCs are. They do not have domains, workgroups, or homegroups inherit to their OS. Thus, PCs on the network don't see them. If you have a USB cable to connect the tablet to the PC, then you may see the device as an added one since the PC's OS can assign the device a drive letter. Most folks want this connectivity to transfer photos and videos from one device to another. If you cannot physically connect the two units via cable, you might try to find an app that will allow you to get the devices talking to each other. There are FTP apps that will get the two together for file transfers and the like.
Jan 12, 2016 | Tablets & eReaders
Need reolutions 4 my finepix HS35EXR
This camera does not allow the user to set resolutions. This camera only allows the used to choose between 3 different sizes of pictures and 3 different aspect ratios (which is basically the same thing)
To change the picture size, you use the shooting menu and scroll down to image size.
I've included the link to the manual for the camera, it's from the Fuji site, and a screen cap of the image size instructions.
BTW, folks here are volunteers... they do this for free.
https://www.fujifilmusa.com/shared/bin/HS35EXR%20manual.pdf 1d9766fb-4792-4bfc-908c-eb3129a6782c.jpg
Mar 06, 2014 | Fuji FinePix Cameras
How to upload photos to a computer
Hi either direct from your camera via usb cable provided you have loaded the software that should come with the camera or via a card reader.
Dec 29, 2010 | Fuji Cameras
Hi Folks, Had my camera just over a year. Put it on today to take photos and it has come up, WHITE SCREEN, USB LOGO TOP LEFT, THEN SAYS COMMUNICATION ERROR. And thats it, cannot go any further ! I have...
pls try to update ur firmware of camera from this link if the problem persist then take it to fuji customer care centre
http://www.fujifilmusa.com/support/ServiceSupportSoftwareContent.do?dbid=872619&prodcat=234644&sscucatid=664260
pls rate FIXYA for the help if u like
Mar 15, 2009 | Fuji FinePix S5700 Digital Camera
Is it not possible to charge via the usb cable?
Hi
this camera came with a external charger, you need to take the battery out from the camera and charge it on the charger.
Thanks,
Ekse
Feb 18, 2009 | Fuji FinePix F610 Digital Camera
Camera says usb connected ALL THE TIME! it wont let me take photos
Screenshot or more details needed. This sounds like camera is faulty, but i dont want to believe it. Are we talking about web cam or like photo camera? If web cam, then just get new one from ebay, no point to have headache when they are so cheap on ebay. But if we are talking about photo camera then make sure you have right drivers installed, all usb settings are correct on cam. I mean, some devices are charging via usb and wont let you take photos unless you change usb setting to media transfer mode. Check those. But if photocam does a photoshot but image is blank then you might have a faulty photo cam
Jan 02, 2018 | Fuji FinePix Z5fd Digital Camera
Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 14, 2007 | Cameras
Samsung SYNC SGH-A707 Cellular
make sure you have latest Studio V3 software and USB driver...downloaded and installed both and internet via phone works great.
Dec 01, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Problem with Playback and Record on camera
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Sep 08, 2007 | Panasonic NV-DS60 Mini DV Digital...
Fuji Finepix 50i won't switch off & has frozen.
There are a few things you can try. I had a fuji that would sometimes do this also. I found low power was one of the main issues. First try a new set of NiMH as alkalines just wont cut it specualy with these older cameras. Next check the memory card door. There is a little tiny switch on the memory door that will turn the unit off if the door is opend. Make sure the door is fully closed and maybe even hold it down tite while you try and use it.
May 03, 2006 | Fuji FinePix 50i Digital Camera
Fuji FinePix 2600 Zoom Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
