Question about Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62hmx84 turn on tv and the red light comes on , but a few seconds the green light will come on , and then turn it off again. this repeats it's self many times and nothing happens
I have the same set. The ballast needed to be replaced on mine when it behaved as you described. Thankfully, I bought the extended warranty but was told this is a $200-to-$300 repair.
Posted on Oct 17, 2008
Replace bulb
Posted on Aug 27, 2008
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Hello, I installed a replacement lamp, thinking it was a lamp problem. Red/green lights blink and turn off after a few seconds. This process repeats and the image never comes on. Please let me know th...
http://www.tristatemodule.com/default.aspx
The bulb gets its spark from a unit called: Lamp Engine. If the lamp engine is bad, you get no spark, maybe the ballast is bad. This place above can re-build your lamp engine. A new one is $500+. Seen some for $600. Service calls are 150-200. You can take out the lamp engine if you've got some tools and the will. Send it to them for an examination and rebuild. They told me if I could switch channels while my set was trying to come on, and I got audio from the other channels, it most likely is the lamp engine.
Give it some thought. Toshiba didn't tell me about that, Geek Squad did. Toshiba doesn't seem to give much of a darn about you once you spend your money for the set. Good luck. RW
Oct 09, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62hmx84
Does your Tv have Input on the remote? if so maybe she hit the input button by mistake. The newer tvs have a few different inputs into them. Like HDMI or regular cable or vcr or dvd. i would try that to see if that helps. Hope you get it figured out.
Jun 27, 2017 | Toshiba 62HMX84 62" Rear Projection HDTV
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
62HM15
Same problem with mine...
Jun 04, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Bad lamp?
If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/52-62HMX84_E_R1_093004.pdf
Jun 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
