Question about Sigma EF-500 DG for TTL Flash
EF 500 Sigma flash
The flash just stoped flashing, its only 16 months old and like new, I used it rarely.
Jim
  • 1 more comment
  • Anonymous Sep 21, 2008
    SIGMA EF 500 DG FOR TTL FLASH
  • frweatherby Oct 02, 2008
    Flash just won't fire - could it be some component has failed and that this could be replaced?
  • heycurt Dec 09, 2008
    I have three of these. The two that are backups and rarely used no longer power up. Contacts are clean and fresh batteries. The one that is routinely used works fine. Any help?
  • 4 Answers
I found the solution by doing the following, all solved:
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I used dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
Posted on Dec 10, 2008
Sigma ef-500 dg st won't work with my d300 or 200 in ttl mode
This Sigma flash is not Ittl compatible. The D300 and D200 Nikon must have Ittl compatible flash to operate in any of the Automatic modes. It is a great flash but will not work on those two cameras.
Dec 14, 2010 | Sigma EF-500 DG ST for Nikon Flash
Sony alpha 350
I have a sigma EF 500 ST flash guns which I bought with nikon F75 some years ago. Would this flash work with canon 500d
raji
May 13, 2010 | Sigma EF-500 ST TTL Flash
Can I use a sigma flash EF 500 with Sony Alpha 350
Yes, if it has a Minolta/Sony mount. The Sigma EF 500 has been producedin different mount, so that the model can fit different cameras from different producers. A Sigma flash for Sony should have SO-ADI written on it.
Apr 25, 2010 | Sigma EF-500 DG for TTL Flash
Sigma EF-500-DG, does not charge and does not become ready
Hello
Thank you for using FixYa for your problem
Always check the batteries first - make sure they have full charge (in the wrong way can discharge them) but if is it still giving the same fault, your flash is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Sigma EF-500 DG Super for Canon EOS TTL...
1. Sigma EF-500 DG ST 2. Quantaray 7500A
A: For Sigma issue:
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I use dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
Nov 20, 2008 | Sigma EF-500 DG for TTL Flash
Replacement shoe for Sigma EF-500
I had the same thing happen. Sent it into Sigma, they replaced it for 50 bucks.
Feb 03, 2008 | Cameras
send it to a sigma agent thay can replace the broken part
Nov 02, 2007 | Sigma EF-500 DG for TTL Flash
Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
Nov 01, 2007 | Sigma EF-500 DG for TTL Flash
Minlota 7d camrea useing sigma ef 500 super flash
check circuit of inside the flash,and clean the circuit, and check all the compenents..may be drysolder, chaeck every thing...
Oct 06, 2007 | Sigma EF-500 DG for TTL Flash
Sigma EF-500 DG for TTL Flash Logo
362 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
Are you a Sigma Camera Expert? Answer questions, earn points and help others
