Question about Kodak i40 Path-Through Scanner
Scanning problem I put mayny page on the scanner kodak i40 and pressed the scanner button. But just only the first page was scanned. I don't know why. Who can help me on this issue?
  • 490 Answers
May be you have selected multipage option. Then all the pages will be part of the same file, you can view them in 'Windows picture & Fax viwer' You need to page down to see the images. Scan only the first page and check the file size. If this file size and the earlier one are different, then it confirms that you have chosen multipage option!
S. Mohan, Chennai, India
Posted on Mar 18, 2009
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
Check kds.log -this is my massage error when i press scan option at canner kodak i 260 "check KDS log" messge error appears when scan option chosen on i40 Kodak Scanner.
Try Calibration routine. If it fails check optics are clean and not scratched. If it still fails change the lamps.The KDS.log is encrypted and can only be accessed via a license key. This is only Available to Kodak reps or through RTS ltd service calls.
WWW.Responsets.co.uk.
Mar 25, 2009 | Kodak i40 Path-Through Scanner
Kodak i40 Scanner - paper jamming
First clean with a damp cloth, then try Isopropyl Alcohol. Dont use solvents. Check if papers are sticky. Stapled papers are 'sticky' even after removing staples. loosen them if required. Notmally rollers last 200,000 to 250,000 scans
Mar 17, 2009 | Kodak i40 Path-Through Scanner
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak i40 Front loading scan
Try downloading the latest Firmware for the Kodak i40 Scanner at the following Kodak.com page: http://graphics.kodak.com/docimaging/US/en/Products/Document_Scanners/Desktop/i40_Scanner/Support/Drivers_And_Downloads/i30_and_i40_Scanner_Firmware/index.htm
Follow the instructions carefully, and make sure that the scanner and the PC DO NOT turn off while doing the Firmware update. I recomend connecting both to a UPS with a known good battery while doing this upgrade.
This should install the latest features including the one that enables front feed.
Otaron
Jun 02, 2008 | Kodak i40 Path-Through Scanner
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
Kodak i40 Path-Through Scanner Logo
238 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
