Question about Microwave Ovens
QUASAR MICROWAVE OVEN REPAIR HELP REQUIRED...
I have a Quasar microwave oven, a model # YMQ9994XW manufactured in August of 1984. The serial number for this oven is NM42140099.
When I plug the unit into a wall electrical outlet, the venting fan runs at top speed and will not shut off until I unplug the unit from the wall outlet. The touchpad has no effect in either shutting the fan off completely, or even slowing the fan down. It appears that I may have damaged a switch as I was attempting to remove the back panel to the unit, and that this switch definitely has something to do with the operation of the fan. When I pull the leads from the switch and connect the two leads together directly, the fan does indeed operate when I plug it in to the wall outlet.
I went to a local repair business to try to replace the switch, only to have the lady behind the counter say that this switch is actually some kind of a thermostat, and that the part is no longer available. She let me rummage around a small box of similar thermostats pulled from other microwaves and let me take a couple home free of charge, but I am unsure of how this part actually functions in my microwave, or if indeed this really is the problem. I have tested the continuity of my own switch/thermostat, and several switches/thermostats in the box, and all of them pass electricity through the contacts.
I also require an electrical schematic drawing or photo of some kind showing which lead from the transformer goes to what contact in the back of the oven. My girlfriend was monkeying around with it and pulled the leads going from the transformer to the oven before I had a chance to label them correctly.
ANY HELP PROVIDED WILL BE GREATLY APPRECIATED.
  • Anonymous Mar 17, 2009
    Maybe not the same problem but a similar problem. I have a Quasar microwave oven. It is an older model. The latch to the door broke so we took the panel off and repaired the latch. After returning the panel to its proper place, everthing worked except the fan and underneath light. It appears everything is connected correctly but maybe not. We were also wondering if there is a fuse for the fan and light which works separate from the rest of the oven and, if so, where might it be located.
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore microwave shuts off after several seconds
Hopefully the hood / vent fan was always on when boiling on the stove top.
Otherwise moisture can get into and damage the keypad or control circuit board.
That may be the problem.
If this is a convection model, it may have a bad thermistor (not to be confused with a thermostat).
The full model has three more digits, in case you need more help and want to post that.
If you or a friend decide to look into it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find an exploded view by entering your full model number here: http://www3.sears.com (the 3 is correct)
Posted on Dec 07, 2007
  • 50 Answers
SOURCE: Whirlpool OTR microwave no oven 'fan'
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Posted on Oct 30, 2008
danforddan1
  • 192 Answers
SOURCE: microwave oven replacement Model#MWF307Z-3 Allegro series
You can look for parts here on FixYa,
good luck hunting, I have the same prob, with my Sharp convection M/ wave. I have been looking for 3 yrs. now and it only a 1982. Good luck DFD
Posted on Apr 15, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2009
  • 3 Answers
SOURCE: Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
Posted on May 25, 2009
I need the manual and cookbook for the old Quasar Heat Wave Microwave Convection
Look at the model number tag and find the FCC ID number.
Enter the number (in two parts) as shown on the FCC ID page here:
https://www.fcc.gov/oet/ea/fccid
In the list of exhibits, look for the owner's manual.
If it's not there, you should be able order it via the links on my part ordering page here:
http://www.microwavecontrol.com/parts.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Microwave Ovens
I requested a manual for Quasar microwave and have not received an answer.
Please contact the place you ordered the manual from.
Fixya would be the place to ask "who to contact" for a manual.
God bless your efforts.
Jul 22, 2016 | Microwave Ovens
Do you have a manual for this type oven?
This oven is too old to find such information. Your best bet is to find something close to it to learn to use it's functions. Here is information of how to repair a Quasar microwave which is very similar to yours.
https://www.ifixit.com/Device/Quasar_Microwave
Apr 04, 2015 | In Microwave Ovens
What is the cu. ft. of a Quasar mqs0963e microwave oven?
About 0.8 cu.ft. - internal dimensions: 8inch x 13inch x 13 inch
Feb 02, 2015 | Microwave Ovens
Quasar Problems
Consult service manual or manufacturer
Nov 17, 2013 | GE Advantium 120 Convection/Microwave Oven
I need to know the wattage on my old 1990's model Quasar Superwave micro/convection oven. Can you help me? Thank you, Gloria
You probably already know, but the wattage is 800. There should be a sticker or plate on the back or underneath the unit with some specs.You can also try calling Sanyo Fisher service for more info at 800-421-5013 Monday - Friday, 7:30AM - 5:00PM PST
Also check http://kitchen.manualsonline.com for a manual. I really hope they can help you.
Mar 29, 2010 | Emerson MW8985W Microwave Oven
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Need users manual
I need a user manual & parts list for a Quasar microwave, Model # MQ9968W built in 1991. Is this manual available in a pdf format or in hardcopy?
Nov 26, 2008 | Goldstar MA-1112 Microwave Oven
Microwave Ovens Logo
531 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
