Question about Lexmark X3550 All-In-One Printer
Paper not feeding
I have been trying to print and the paper won't go down far enough for the rollers to grab it so it is inking up the rollers but not on the paper at all
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Aug 26, 2008
I have got an HP OFFICEJET PRO L7480 (All in One) and a problem with the paper feeding. I tried all the usual things (resetting, cleaning rollers, etc.) It seems like it is mainly a problem with the...
the problem in your printer could be the plastic gear attach to the end of the rubber roller that grabs the paper. Look closely and see which gear's teeth is broken or already worn out. This cause the delay in the timing of the rotation of the roller.
Check also the mechanical timing of the roller. if you can unlatch the tension spring / lock to make the rubber roller moves freely, do it....position the rubber that grabs the paper, try 90 or 180 degrees from its previous location.
Hope this helps!
May 10, 2011 | Office Equipment & Supplies
Desk Jet 970Cse professional series will not pick up the paper to print...
Over a period of time, the friction rollers (rubber rollers that grab the paper and feed it through the machine) build up residue, usually dust, and this grime makes the rollers too slick to work properly. Remove the cover of the machine, or just open the top cover if it leaves you adequate access to the rollers, then, using Q-tips and some plain rubbing alchohol (light amount) clean the surface of the rollers. Let them air dry, then see if this improves the tackiness of their surface enough to grab the paper and feed it again.
Dec 09, 2010 | Computers & Internet
Hi! The paper won't feed to print..what am I doing wrong please? We have tried new paper' older'less'and more' the roller part just will not grab!
Check paper feed machism.Ensure that the feed roller is rotating when you command print.See also that there is no obstraction in the paper path.Sometimes there could be a foreign pacticle.Also try to clean feed roller so that there is friction between paper and roller.
Jul 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Printer says clear paper jam. There is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Lexmark X5250 All-In-One InkJet Printer
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Paper Feed
Try turning the printer upside down and shaking it. Sometimes something small like a paper clip or Lego brick gets down inside and will prevent the paper from feeding.
Apr 04, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X3550 All-In-One Printer Logo
179 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
