Question about Brother HL-5240 Laser Printer
Red status light came on red and toner light --orange
Put new toner in --no fix. Have tried factory reset --no help Have tried several peoples solutions i.e. remove cartridge push go 1 sec instal cartridge keep door open push go button 1 sec then close door push go again --no joy. do you have any ideas please
I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck.
Posted on Sep 21, 2008
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
New toner, starts, but STATUS button lights red and toner orange light comes on
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Brother HL-5240 Laser Printer
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Toner light and Status light stays on
well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Sep 11, 2009 | Brother HL-5240 Laser Printer
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Jun 07, 2008 | OKI C3400n Laser Printer
Had it a while and it stopped working.
Come on copier tec you should know better, need to know which light is showing orange, Drum,toner,paper,status?
Intuition tells me that you have a orange toner light and a red status showing, and you are using a non OEM toner, but thats guessing.
Dec 26, 2007 | Brother HL 5140 Laser Printer
Brother HL-5240 Laser Printer Logo
570 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
