Question about Excelstor Technology J840 Hard Drive
Formating the hd
My bios shows it but how do i format the drive? where is the "manage" button in the "my computer" icon? i cannot locate it and i believe i have the same problem.
I dont UNDESTAND
Posted on Nov 27, 2011
Unable to format a Western Digital Caviar Green 2TB SATA 3.5" Desktop Hard Drive
In your formatting on a windows machine you can format by right clicking the new drive and select format. Or you can format by opening manager by right clicking on my computer and choose manage then go to disk management and locat the new drive and right click format
Mar 11, 2011 | Western Digital Caviar Green 2TB SATA 3.5"...
Hd fujitsu model mpa3026at is detected in bios, but the explorer do not display the hd.
If it is a brand new drive it needs to be initialized then formatted before Explorer or My Computer will display it. Right-click on the "My Computer" icon and select "Manage" then "Disk Management." You should get a prompt that a new drive has been detected. Follow the instructions to initialize it then format it to NTFS. After that it will show up normally.
Jun 09, 2010 | Fujitsu MPA3026AT 2.6 GB ATA-33 Hard Drive
How do you initialize or format the hd in this unit under Windows xp?
Right click on the "My Computer" icon on your desktop and choose "Manage". Then select the "Disk Management" option in the left column. This will bring up a list of the drives in your system. From here you can right-click on partitions to delete/format/etc.
May 21, 2010 | Thermaltake A2397 Silver River R 2.5in...
WD 5GB nternal EIDE drive is detected by BIOS but not by Win XP.
New drives are not usually formatted, so the drive will not show up in the drive list when My Computer is opened. As this may be the case, the drive will need to be initialize and formatted.
To do this make sure you have administrative rights and locate your My Computer icon which is located in the Start menu or on the desktop. Right click on the My Computer icon then select "Manage" and click on it.
You will be presented with the Computer Management console. Locate and click on "Disk Management" under the Storage part of the management tree.
Many times when this is opened, the system will present you with a wizard to initialize and format the drive. If this is the case then follow the wizard to complete the task.
If this did not happen, look at the list of drives in the list. If the computer recognizes the drive it will appear without at drive letter next to it. If this is the case a right click on the drive with out a letter will allow you to initialize and format the drive.
If the drive does not appear here, then over to the far left in the Computer Management console, find and click on "Device Manager"
Once the device manager is open a tree with all the recognized devices will be displayed. Click on the + sign next to Disk Drives. If the drive is not listed here then the computer does not see it.
If this is the case highlight and click the computer at the top of the Device manager that has the name of your computer. Now right click the computer icon and select the only option witch is "Scan for Change". The computer will look for devices for a moment or two. When complete see if the drive is now listed under Disk Drives in the device tree. If so follow the steps above to initlize the drive and format it in the Disk Management part of the console.
If the drive did not show up, shut the machine down and check the connections to the disk drive.
Also make sure the drive is properly jumped. Most Western Digital Drives have a jumper diagram printed on the label. Set the drive up for single drive or cable select.
After restarting the machine, enter into the BIOS to make sure the machine is in fact seeing the drive. On a Dell Dimension this can be done on restart by pushing the F2 key. This must be done quickly right after start up.
Once in the BIOS use the arrow keys to navigate. Locate the section for hard drives and verify the machine is in fact seeing it. It may be that the secondary IDE channel has been disabled. Make sure it is enabled. Also make sure the drive detection is set to auto if the option is available. Once complete make sure to save changes to the BIOS. When complete the system will be restarted. Allow the system to boot Windows. It may recognize the device now and prompt with the wizard.
If not use the steps above to check the Disk Management under the Computer Management console to see if it is there.
If the drive is still not there try testing it in a different machine or seek professional services to rectify the issue.
Feb 02, 2010 | Dell Dimension 2400 PC Desktop
I've installed a second HD in my Dell 9150, it's is recognized in the BIOS, but I have a problem accessing the HD. When I go to my computer icon and open it, it is not present.
Hi Dear,
As you have said, that hard drive is recognized at bios level. Then the primary problem seem to be that it might not have been activated.
If you are using windows XP then go start menu===>>> my computer icon===>>> right click on it===>>> go to properties ===>>> go Hardware ===>>> go to device manager. Check there if both the hard drive are shown or not.
If it is present then go start menu===>>> my computer icon===>>> right click on it===>>> click on manage ===>>> disk management===>> > there you can see your newly hard drive installed. Format it once and then activate it here.
hence doing this step you should be able to access your newly installed disk.
For windows Vista. Do the same procedure.
Hope this will fix your problem.
If not please do write to us again, we will be pleased to solve your problem.
Have a nice day.
Nov 09, 2009 | Dell Dim.9150 Pentium D 820 Dual...
I Transferred a hd into this pc from another pc. This hd is ntfs format.The second hd in this pc is the fat format. In explorer it shows the second hd as the d drive. When i click on it it says this hd is...
First of all, I hope the harddisk which has the operating system on it, and which the system is booting from is NTFS formatted. Try and crosscheck this first. Then after doing this, try and assign a new drive letter to the harddrive that is showing error from the Systems Management Page.
This is how you do that : Right-Click on My Computer Icon, Go to Manage, Click on Disk Management, Then when you get to this place, You should see ALL the HardDrives installed on your system including the one singing for "format me"...lol.
Then locate and right-click on the harddrive, and select "Change Drive letter and Paths", and select any new, unique letter for your HDDrive. then click on OK.
Hope this helps.
Goodluck.
Jul 13, 2009 | Computers & Internet
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Computer not locating Hard Drive
new hard drive needs formatting. go into the hard drive maintenance settings run this program diskmgmt.msc from run on start (home button) most windows (win 10 right click over home button) type in run box. you will see your drives, the one that says unformatted is you new one. in the box right click to format the drive or use the menu at the top to format and set drive after its done windows with be able to use the drive,
Feb 01, 2018 | Buffalo Technology DriveStation HD-HC500U2...
I added an SATA HD to a system whose C and D drives are a WD 400GB PATA HD. The Hitachi 750GB drive has no jumpers for master/slave. After boot-up the system sees it but assigns no E or other letter...
  • Right Click [My Computer] and click Manage
  • Click Disk Management on the left side
  • Inspect the drives listed. The new drive may need to be formatted for the operating system to recognize it and assign it a letter.
  • To format the drive, right click the drive with no letter, and click Format. Choose your format (Preferred NTFS), and quick format the drive so that windows recognizes it.
Mar 10, 2009 | Hitachi Deskstar 7K1000 750 GB SATA Hard...
WD Elements 1TB stopped
I would remove the data with another computer using a usb adapter and then re format the drive but check your motherboard will support more than 528Gb chunks. If it won't, partition the drive accordingly.
Jun 11, 2017 | Computers & Internet
Excelstor Technology J840 Hard Drive Logo
48 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
Mohammed Ebrahim M
Mohammed Ebrahim M
Gerard McHugh
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
