Question about Olympus Camedia C-770 Digital Camera
Settings that must be set before... the external flash feature
Are there any settings on the camera that must be set before you can use the external flash feature?
    Master:
  • 852 Answers
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Posted on Sep 04, 2005
4 Suggested Answers
SOURCE:
neta
  • 852 Answers
SOURCE: Are there any settings on the camera that must be set before you can use the external flash feature?
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
neta
  • 852 Answers
SOURCE: Settings that must be set before you can use the external flash
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built- in flash and the Olympus FL-20/FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
neta
  • 852 Answers
SOURCE: Any settings that must be set before you can use the external flash feature
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Nikon L810 pop-up flash raised but the camera is not detecting the raised flash
You have to set the on board flash you may have external fllash set on even if you reset your camera go to menu then flash/bracketing then TTL set for flash on camera
Dec 24, 2012 | Nikon Coolpix L810 16 Megapixel Digital...
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
External Flash
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something. I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
External flash for the 3000Z
bought the Metz 32 Z-2 that was recommended by Epson. I did a great deal of searching/researching on the web, and eventually came to the conclusion (my personal conclusion...YMMV..as well as others) that it was worth the price. I've also had two (non-digitial) pros hold the metz name in very high regard. I like it so far although I haven't used it much for nice portraiture. I did use it at the beach one night in the *dark* from 10 meters (couldn't see *anything* on the LCD when snapping the picture) and a few turned out really nice. Some were not in complete focus, but hey, it was dark. I will say it is much larger than I expected. When mounted on the 850 it felt nice. But with the 3000 being a little smaller, it is rather large. With a teleconverter lens and the flash mounted together, the whole ensemble feels rather nice. I'd recommend finding one in person first. It does have about all the features one could want tho...
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Newer features
4 Nickel Metal Hydride (Ni-MH) Batteries w/Charger included. • 8 MB SmartMedia Card included. On the web it says that Two 8MB SmartMedia Card included. • 6 Step Manual White Balance/ Color Temperature Control. • Burst Mode: up-to 5 images in 1/3 second intervals at any resolution. • External Flash Sync/PC flash connector. • 3 position quick focus settings: 1.3ft, 8 ft., and infinity. • Battery Saving Mode. • Rapid Fire Capabilities all resolution modes (even with the flash on). • 6 Mode pop-up flash system, including Auto, Red Eye Reduction, Fill in, Fill in with External Flash, External Flash and Flash Off.
Aug 31, 2005 | Olympus D-500L Digital Camera
Olympus Camedia C-770 Digital Camera Logo
439 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
