Question about Oreck XL Ultra Bagged Upright Vacuum
The vacume will not turn on
I plug it in, turn on the switch and nothing happens
  • Anonymous Aug 29, 2008
    I plug it in and NOTHING happens! Help what have we done?
  • kool4lisa Apr 02, 2009
    I had the same problem this morning. wandering if you figured it out yet?
  • 3 Answers
The spade connections inside the handle have come loose. take the screws out and connect the wires back. thats it
Posted on May 29, 2009
No power on my pro team proforce 150xp
Generally a bad switch . We have the replacement fix.
Qualitymro.com
Dec 02, 2015 | Pro-Team ProForce 1500XP Commercial...
Nothing happens
it could be the wiring coming from the vacuum itself you might have to change it.can be brought at any electrical wire store have you checked the plug wiring is it all intact or has some came out from the terminals?
Apr 06, 2014 | Electrolux Z4735AZ Gazelle 1900W Upright...
The machine is not turning on at all, what do i do?
first check electrical recpt make sure it hot and not tripped.
second if electrical recpt is hot check cord for continuity with meter.
if cord is fine check switch for continuity. usually one of these three things that cause a vacuum not to turn on.
Jan 08, 2013 | Bissell 6594 PowerForce Bagless Upright...
Central Vacuum works when power switch on canister is turned on, but will not turn on when connecting the hose.
DOes it not work on any of your wall inlet valves? If all wall inlets appear dead take a coin making a connection with both of the contacts inside the throat of the valve. If the vacuum turns on the problem is in your hose or the powerhead. If nothing happens plug in your hose and try wiggling the low voltage wires at the vacuum as you leave the hose plugged in with the swich on your in the "on" position ( if you have a switch) If still nothing unscrew all valve plates from wall leaving wires attatched. Inspect all connections for loose wires or wires that have come off terminals. .
Nov 09, 2009 | Kenmore Vacuums
My Dyson Animal DC07 will not turn on. Nothing happens when plugged in and the switch depresses
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, take the vacuum to your nearest vacuum repair shop
Aug 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson07animal won't turn on
First try another outlet. The likely problem is that your Dyson power switch may need to be replaced. If the vacuum cleaner switched off whilst you were using it you may be experiencing a thermal cut-off. Call the Dyson helpline, they'll let you know what your options are to fix your vacuum cleaner.
Jul 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
My Rainbow stopped running
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Jun 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Off/on switch does not work
The on/off switch in Hoover Windtunnel upright vacuum cleaners is operated by a lever in the handle assembly.  remove the two screws on the back ovf the vacuum and see if the lever has bypassed the switch assembly.  if so, re-assembly should fix the problem.  It is also possible that the switch activating lever has broken.  If so, replace the activating lever.
Oct 24, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Oreck XL Ultra Bagged Upright Vacuum Logo
251 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
