Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Constant intermittent loss of connectivity, even with new gt704wg router
Over 2 months ago I started having issues of losing connectivity of my verizon dsl. I would reset as they said and it would be fine, for a while. The one Sunday of all days, the modem would not reset and I got all red lights. SO I call in, they say push reset button and soon and further yakityyak, nothing works. they say buy a new modem but I have to wait til monday. I say nope, going to town to buy one and of course no one in town has one, not even radio shack. they say I have to get it from dsl provider directly. I come home very disgruntled, take old modem apart and plug it is. Viola it works. but intermittent connectivity issues continue. Next Sunday, same thing. DSL goes out. I call they INSIST it is the modem, so I drive 30 miles to a town that has a circuit city and but this fancy GT&704WG for 100 bucks. And gues what? It did not reslove the issue. Now a month later, I even had my phone line dry looped and I STILL lose connectivity on and of all day long. I say itis int wiring, they say no and wont come out and fix it. Can ANYONE here be helpful before I go postal on Verizon? Please I beg!
  • The Blue Hag Sep 18, 2008
    Helpful but I am not sure that is the problem; I don't run my AC often and I have never noticed any rhyme or reason to the problem such as anytime the AC or microwave start up it goes out; everything else is the same as always; they even came out and installed a splitter and it is still doing it.... now they say they need to do some "line conditioning" whatever that is. I dont know if modem or not as this was occuring before I got this new modem...
  • The Blue Hag Sep 26, 2008
    Update:
    Verizon has not been able to fix to date but is now blaming the issues on the router. I spoke iwht a supervisor as to how that is possible and he admitted it the router problem was caused by their wiring, which he sas they fixed, but it "shorted out" my brand new router. I have to wait now for them to send me a new router and see if that fixs problem but I am highly skeptic....
  • 4 Answers
This issue drove me nuts for a while. I too have verizon dsl and use a verizon branded actiontec router (gt704wg).
The problem has to do with DNS configuration. Not exactly sure what the true root cause of the issue, whether with the Router / Firmware or on Verizon ISP side, but I figured out how to make it work.
DNS is what translates internet IP addresses such as http://198.105.192.72/ into recognizable Enlish language terms (http://www.espn.com). When you type espn.com into your browser, your request travels out to a DNS server somewhere which performs the translation into the numbered IP address and directs you to the appropriate website.
The problem you are having is that your requests aren't finding a DNS server to do the translations...
You can test this by trying: http://198.105.192.72/ in the browser URL hich should resolve to espn.com. If the website resolves, it means your internet connect is working and proves it is just a DNS issue.
If this is the case, then there are a few possible places where a faulty DNS configuration setting might be causing an issue. (Local PC, network router, ISP).
Try configuring your router to use static DNS : using the following address for DNS servers: 208.67.222.222 and 208.67.220.220
more useful info here:
https://www.opendns.com/homenetwork/start/router/
If that doesn't work, you can hardcode the addresses on you pc by going to:
network connections > select the connection >properties > Internet Protocal (TCP/IP) > properties
Posted on Oct 04, 2008
It might be that you have a voltage drop. I noticed that this modem is very sensitive to voltage 'dips' and it will 'reset' itself if even the slightest dip in power hits it.
I have a A/C that sucks power when it cycles and every time it does I lose the internet connection. So I set up a 12 volt battery with an DC to AC inverter and run the modem off of battery power.
That might be the problem your having.
Posted on Sep 18, 2008
CDX-GT4301P sony car radio loses station/settings memory intermittently.
At the back of the head unit, there are usually two power connections to the car battery live. One is via the ignition, and the other is (usually) a fused connection that connects directly to a relay or fuse that has constant power, even when the car is switched off. This constant power allows your head unit to hold its memory. If the loss of memory is intermittent, it could be a loose cable or corrosion on the fuse.
Oct 22, 2013 | Car Audio & Video
2 days ago my router seem to lose connection and says theres no modem or internet connection.. and modem is perfectly fine. After i unplug and replug the power, it works for another 5to 20 mins then have...
This is because your router is dropping the connection with your ISP Modem...
It can be even an issue of modem...
To isolate the issue, what you can do is... You can connect your computer directly to the Modem and you can check for any intermittant connectivity...
if you dont have any problem with your modem, then definitely its gonna be the problem with your Belkin Router...
Doing a reset for the router and reconfiguring will resolve the issue in most of the cases...
If in case if it doesnt works, then you can do a firmware update for the router (that would be found in belkin router support website)...
Even then if it is dropping the connection then definitely it is a faulty router...You can ask for a replacement if the product is still under hardware & software warranty...
i work for belkin...
you can reach us any time in 1800-223-5546 if u are calling from USA...
we work 24 X 7....
For any other countries search in www.belkin.com/support
Dec 09, 2010 | Belkin N1 Vision Router
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
GT 704 WG telephone line DSL filter no work
Try to replace the filter first. That will solve the issue.
Jun 29, 2009 | Actiontec GT704WG Wireless Router...
The actiontec gt704wg works fine
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Change your SSID and encrypt with WEP or WPA security.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 04, 2009 | Actiontec GT704WG Wireless Router...
Verizon DSL, keep losing signal, 2 different routers, same issue
try upgrading your verizonservase to the power pake one they might have a better router for you wich is the 29.95 on for high speed internet servas
Reconnecting the modem
They do not have any install CD. You have to set it up and then call Verizon to help you set it up completley but you swill be able to get to the 192.168.1.1. site so you can get it online
Sep 21, 2008 | Actiontec GT704WG Wireless Router...
Frustrated beyond belief
Update the firmware:
Follow the instructions carefully:
http://www.actiontec.com/support/product_details.php?pid=92&typ=all
http://www.actiontec.com/support/index.php
Please remember to rate all users who assist you for free :)
Aug 26, 2008 | Actiontec GT704WG Wireless Router...
Intermittent losing internet
Your modem/router is not good. I used to have a Linksys-B router that did that, just gave up on it an bought a new one. You can probably find a new one for about $20-$40
Aug 06, 2008 | Actiontec GT704WG Wireless Router...
Intermittent connectivity
Check to see if you are losing the DSL or Internet light on the modem when you lose your onnection. If so, then check with your IP provider, that may be the problem.
Apr 11, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
313 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
