Question about Uniden Lands Phones
I can't figure out how to switch my Uniden 2.4 GHz (no digital display) from pulse to tone. Pushing the *tone button only changes it for the current call. Each time I hang the phone up it goes back to pulse dialing. Please help
    Problem Solver:
  • 11 Answers
Uniden 2.4 GHz whats this
Posted on Aug 26, 2008
How can I change pulse to tone (dialing)?
switch on the side of phone, switch from pulse to tone if no switch go into phones settings and it will be in the set up part of settings.
press the helpful button
Feb 05, 2016 | Uniden DECT 6.0 Cordless Phone
Uniden DX18560-2 cannot switch back from pulse to tone HELP!!!
Hi, Below is the link for your phone's manual. It describes how your phone was changed from tone to pulse in Section 3-1. I would go through those steps again to see if the phone could be changed back to tone in the same manner. Hope this helps! Hal
http://www.uniden.com/pdf/DXI8560-2om.pdf
Jun 09, 2009 | Uniden Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
The ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
May 18, 2009 | Uniden TRU4485-2 Cordless Phone
Can't get phone to switch from rotary dial to plain dial tone
Hi, there should be a button located where the power cord and telephone line hook up, It says pulse/tone, Make sure it is in TONE mode.
May 14, 2009 | Uniden 2.4 GHz Expandable Phone System...
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
232 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
