Question about Magellan Roadmate 760 GPS Receiver
Have had my Magellan for almost 2 years and was working fine until today. When I pressed the button to start it, it would not turn on. A few times you saw the start up screen for maybe 3 seconds than it went blank. Have no clue what my next step should be.
  • Mama1218 Sep 24, 2008
    As I could not figure out what was wrong with it, I called Magellan customer service and was told my Magellan Roadmate was now known as "a legacy". Imagine not even 2 years old and it is "a legacy" and therefore parts are no longer made for it!! They did tell me I could mail my unit to them and they would "upgrade" me to another newer model for an additional $200. I decided not to as I want to get away from a Magellan product because of this problem.
    However, I do want to thank you for taking the time to try and help me. You are probably right, that the problem is the cradle and with it being so expensive, why bother! Thanks again!
  • CarbonBronze Nov 05, 2008
    I went to use my 760 this past weekend and could not get it to power on. At first, I thought it was my power socket not sending power to the unit. (The power plug is so tight that it pulled my socket loose). Got the power socket repaired and again tried to power the unit on.
    No dice. Went inside the house and used the AC connector. Can't even get it to power on this way. No blue light, so power must not be making it all the way to the GPS unit, however I do hear a slight buzz.
    After trying to figure out what the problem is, it must be the cradle.
I had the same problem. A new cradle and DC cord fixed everything. Anyone have any idea what model Magellan will upgrade you to for $200.
Posted on Nov 06, 2008
    Problem Solver:
  • 11 Answers
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Posted on Sep 24, 2008
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
I need an upgrade for my magellan Roadmate 760
You can download an upgrade for this unit from the Magellan website for free. Maps can be upgraded but they cost about $80, and that doesn't seem worth it to me. See if that works for you.
Dec 13, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 does not find satellites
I recently i had the same issue. Open the four screws from back. remove the back cover carefully (tahe care of the attached cables).
check the atena wire connection (gray thin wire). both the ends should be seated firmly.
in my case, soldering at one end was broken. had to resolder. its working now.
Nov 04, 2008 | Magellan Roadmate 760 GPS Receiver
My Magellan Roadmate 760 turns on and brings up the Magellan screen and then it locks. Can anyone help.
Sep 02, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
The cord for the roadmate 760 takes a 3 amp 250 volt fast blow fuse.
Feb 09, 2008 | Magellan Roadmate 760 GPS Receiver
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
Power suply Loose contact
only way to get that fixed would be to contact Magellan to get it fixed or if your is the kind with the power dock on the back you could order that part from tigerdirect.com
Oct 24, 2007 | Magellan Roadmate 760 GPS Receiver
MAgellan Rodmate 760
You should return it and get another one.
Jun 15, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
275 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
