Question about Mitsubishi WS-65809 65" Rear Projection Television
Change bulbs I have a WS-65809 65" and the green bulb has burned out. Do I need to replace all the bulbs or just the one that burned out? Is replacing it/them easy and how do I do it?
    Problem Solver:
  • 5 Answers
Most are easy to switch out just make sure to be careful doing it cause they aren't cheap . u can change just one but the others probably should be changed too. the brighter bulb is probably going to throw off the other colours . for what u would pay for in bulbs u would be better off just switching to the samsung led system . one bulb .high def , upgradable . and bulb replacement is cheap . just a suggestion before u go dump a wad on three new bulbs . its a slim tv too that is hangable
Posted on Aug 29, 2008
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help! Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
Replacement bulbs
Probably through Mitsubishi only.
Are you sure you want to pay the cost of the CRT'S?
These are the Part Numbers for each of them.
RED CRT --------251C217040
GREEN CRT----251C217050
BLUE CRT-------251C217060
Mitsubishi's Parts Deparment 1800-553-7278
Nov 16, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Same Green Light flashing!
The timer light flashing usually means that the bulb needs to be replaced.
Jul 25, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Projector tv the red and green colors are not in sync
no its a convergence tube problem u shud change the green tube.
its the exausted one in this case.
Mar 15, 2009 | Philips 60PP9202 60" Rear Projection...
Bulbs keep burning out
When you replace headlights in today's cars, DO NOT TOUCH THE GLASS OF THE BULB!. Handle the bulb only with the packing material the bulb ships in, or with a clean dry cloth.The oils in your skin will cause premature failure of the bulb.
Also, check the sockets (car side) carefully to make sure they are not burned.
Feb 03, 2009 | 2006 Hyundai Sonata
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Distorted color...Bulbs???
no is does not. did you try to do the convervence from the menu?
Dec 06, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
