Electrical smell as if something burned up inside
Double vision of images, blue on left of image red on right of image. Blurred image. Turned on with remote three times and three times it turned off in 3-5 seconds by its self. Turned on directly at the tv ,it did come on but began to smell of something electrical.
  • 1 more comment
  • rbihr Aug 26, 2008
    It is a panasonic model PT56WXF95A Made in 1999 Serial #MY92850022
    Made in 1999 Panasonic rear projection model PT56WXF95A serial# MY92850022 has red and blue on left and right of the images. Has electrical smell. Blurry picture.
  • rbihr Sep 02, 2008
    My problem was ic convergance. Why couldent any of your consultants come up with this solution? Three out of three tv reparir shops came up wilth this as the problem with the same proplem discription?
    Master:
  • 521 Answers
Its the problem of convergence STK ic. there are three such ics may be one or two or all the three would be faulty please get it replaced.to make your tv work again.
thanks.
please rate the solution ,
regards.
fixya expert team.
Posted on Sep 02, 2008
    Master:
  • 623 Answers
This smells like a burned fuse
check your board
good luck
    President:
  • 1,263 Answers
Anytime you smell burning. it's a good idea to unplug it and keep it that way. considering what you described your power supply module is definitely fried. hopefully you cut the power in time a qualified repair tech should help you with the replacement of the defective parts. ( don't do this yourself) you will save yourself from making the problem worse. and it will cost you more than you intend on...good luck please rate
    Genius:
  • 2,035 Answers
There is short in the ckt board which is causing the burning smell ,this problem with faulty component,give to local TV service center get it fixed....................................
Good luck....
  • 1,879 Answers
Turn it off.
If you don't do electronic repairs, call a repairman.
Posted on Aug 26, 2008
    Guru:
  • 674 Answers
Make and model would help to solve problem . somthing let loose in your set . you might get lucky to open it up and check the boards . if you smelled somthing it got really hot and should show signs,
  • 6,487 Answers
Can you please inform us the model and brand of this unit..there's a possibilty of a busted fuse or a short circuit inside it, better take it to a repair center near you and let them fix it..
  • Mark Gil
    Mark Gil Aug 26, 2008
    There's a possibilty of a busted fuse or a short circuit inside it, better take it to a repair center near you and let them fix it..
  • Mark Gil
  • 2,071 Answers
Just cliick below for how they repair there DLP TV and a picture guide how to replaced the lamp,fan and color wheel ..
http://www.jangro.com/a/2006/08/15/samsung-dlp-frequent-questions/
how to change your Samsung DLP Lamp.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Getting red, blue and green halos around images
I had a similar problem with red halos around images on my Hitachi rear projection TV. The problem was that the red convergence chip burned out. I replaced that and that fixed the problem. I found several forum posts on similar symptoms and fixes for Sony rear projection TVs by searching for "Sony rear projection convergence problem." Likely you've already tried the auto-convergence function for your set, if it has that.
Feb 28, 2010 | Sony KP-46WT500 46" Rear Projection...
Image appears double and slighly off when viewing
I was having a double vision problem with my Barska 10-30X50 zoom, 195FT/100YDS binoculars. One image was always higher than the other. This was tolerable at low zoom, but was further aggravated the more I zoomed in. I found that I could grasp both barrels and twist them in opposite directions (one side up, the other side down) and force the two images to merge--but that was a strain and an unpleasant viewing experience. As an experiment, while looking through the binoculars, I grasped the far end of the right barrel and twisted it on its axis. Nothing happened at first, but after a certain amount of resistance it began to rotate independently of the body. Lo and behold, this shifted the barrel's axis, and the image for that eye moved vertically! I turned it until the two images merged, and now I'm thrilled to say that the problem is solved! I don't have a clue if this would work on any other brand or model, but it's worth a try!
Apr 06, 2009 | Tasco Sonoma 16-840WA-1 (8x40MM) Binocular
Samsung Rear Projection SP43W6HFX- Smoke + Blurred Vision
Convergence IC's are busted.....google it. You'll find loads of solutions!
Nov 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Electrical smell
did you get this fixed
thanks paul
Aug 26, 2008 | Televison & Video
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Double image, blue and yellow images
convergence ic are going or have loose connection in the convergence amp ic area.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Hitachi 43FDX01B TV
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Double image - not covergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
HELP!! zenith r57w46
go to the nearest PC repair shop..your board/processor burned out.
or if you have still a warranty for the laptop better contact the  supplier were you bought it and as for a replacement.
Oct 29, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
