First do not panic! It is possible to
recover your pictures if you take care. Take the card from the camera (powered
off) and if it has a "write protect" tab then lock it now. Do not try
and write anything to the card or you risk causing more problems. You can either plug in you camera to the PC
as it should appear as a “Removable
Drive” or put the card in a card reader attached
to your PC. Next, if you are comfortable with using a
PC then you can download a FREE utility that will recover your photos from the
following link: http://www.cgsecurity.org/wiki/PhotoRec If you need something a little more
"user friendly" then you will need to buy the software. If you search
the web for photo recovery software you will find many. One I have used successfully is RescuePro
that used to be bundled with some Sandisk products. Now you can get it from the
link below: http://www.lc-tech.com/software/prwindetail.html. You can try the demo to see what you can
recover before buying. Remember - Do NOT try & write anything
back to the card until you can recover your pictures to your PC safely! Please take a moment to rate this solution
& let us know if the information given was useful to you – Good Luck! Informatica
camera will not focus correctly. when shutter button is pushed half way down the picture goes...
(More)
camera will not focus correctly. when shutter button is pushed half way down the picture goes blurry, and if you take the photo it actually turns out blurry.
