Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Program channels lost the remote. the tv will go up to channel 28. how do I program the tv to receive all of the chanels on the cable?
  • Anonymous Aug 28, 2008
    I cannot the menu to open on the screen without the remote. The TV is a sony trinitron. The controls inside the pop-open door read from left to right as follows:
    Speaker-auto stereo-mts-sharp-bright-color-hue-picture(- +)-cable(off-on).
    Above the pop-open door exposed to all they read from left to right as follows:
    tv/video channel
    timer/block volume
    How do I manuver the switches to open the menu or the auto add channels.
    Thanks for your help
  • 2,071 Answers
Just Press Menu> scroll or Navigate or Select Auto program, then press enter> (to Move press volume button -minus or +plus,and to enter or OK press TV / VIDEO) then select auto program to automatically scan channel. Choose Air if you use outdoor antenna,if cable choose Cable,whatever the result ,just post so i can assist..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 26, 2008
The TV works however I cannot get the set to read the channels. I have cable but no cable box. Have tried to program it for over 3 hours. I've tried it using ch.3 and ch.4. through the remote. After I scan...
U used the tv remote go into ur tv SETUP.Pick Cable,before u scanning for cable chanels?U have pay cable?Must scan for cable chanels,by setup for looking for cable channels.
Mar 18, 2011 | Televison & Video
I have a brand new straight from box LG TV model 32LD320. I have unpluged the HDMI from old TV ( where was working 100% OK) plugged into new TV. Mains switch on - and cannot get any chanels to report on...
HDMI sends video from a source likea bluray player or 'cable box' to tv it will not send signal so you can program channels from it
turn tv to the HDMI input you plugged device into and watch cideo from that source
you will need to connect some type of antenna to be able to program channels on tv
very few tvs need channels programmed these days since most people hook up a cable or sattelite receiver and change channels that way
hope this helps if not give me more speecific details and i can help you more
good luck
Mar 13, 2011 | LG Televison & Video
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME...
I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
Nov 24, 2009 | Panasonic CT25G7 25" TV
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Aug 16, 2009 | Televison & Video
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
Lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
