Rca f36673et flashing picture
My rca's stuck on ch.03 and the sound and picture is cutting in and out wthf ups with tha?
  • jafjames84 Aug 26, 2008
    already have univesial remote forgot to say that no buttons work either
  • jafjames84 Aug 27, 2008
    fixed it myself!!! the front buttons are stuck so i used my universial remote as suggested and got it to work properly thanks to everyone for their suggestions.
  • 1,800 Answers
Yea u the man always
Posted on Aug 27, 2008
  • Jalal Sordo
    Jalal Sordo Aug 27, 2008
    always try things in ur own maybe u r the one who gonna solve it !!
    Sergeant:
    Champion:
  • 271 Answers
Your problem is that you have a problem with chanel 3 ???
If so...the problem is improper tuning (channel tuning also can be lost automatically)...
no problem with the remote or any thing else >> what you need is to re tune the channel...
if you don't know how to tune...you can look into the user manual...
reply if you want to know more..
Please Don't forget to Rate Me..............................................
thank you
Posted on Aug 26, 2008
    Brigadier General:
  • 6,966 Answers
A couple of possibilities:
  • faulty firmware (flashing required);
  • channel memory erased (needs reprogramming);
  • depending on how cable signal goes in (VCR, tuner or Cable box), a probable fault in your incoming cable signal;
  • hardware problem which could simply be a loose connection, cold solder in in some cases, logic circuitry.
The last of course requires familiarity with electronic circuitry and components, use of a soldering iron and perhaps even a DVM. Should you be uncomfortable, then perhaps your best bet wold be to seek the services of a qualified professional.
As I have normally responded to similar concerns on probable cold solder issues, Additional information:
  • cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
  • Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have posted on then off then on, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 2,071 Answers
If your TV still does not turn on after unplugging , then you will have to retry for a longer period of time. Try longer periods of time such as overnight. And you must unplug the monitor from all connections that can supply power to the monitor. It is recommended to remove all connections. If still not working,then it maybe a loose contact or cold solder.
Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 26, 2008
    Resetting the TV
    If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
    NOTE:
    Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
    1. Unplug the TV power cord from the power outlet.
    2. Unplug any connected devices (DVD, Set-top boxes, etc...)
    3. Press and hold the TV power button for five seconds.
    4. Plug the TV power cord back into the power outlet and turn on the TV.
    5. Open the on-screen menu to confirm that the TV is responding again.
    6. Turn off the TV and reconnect the devices.
    7. Turn on the TV.
    hope this may help;
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Sep 01, 2008
    Did the solutions from all of us experts solved your problem if
    not then let us know the current updates so all the fixya experts can
    assist you further.
  • 6,487 Answers
My suggestion is to buy a universal remote, which comes with instructions to program your remote to your tv, and you should be able to fix your problem
Good luck........
  • Mark Gil
    Mark Gil Aug 26, 2008
    How about changing the channel from the TV control itself, did you try that??
Want to use all 5 speakers on surround sound yamaha htr-6230 on tv programs. how set up?
Depends on the audio source for your TV sound. If it's a digital cable box, run a coaxial or optical cable from it to an available digital input, assign it as "TV" and you're done; or if the cable box has 5.1 analog outputs, usethose to the Multi Ch imputs.
If your TV sound source is only RCA cables (stereo) you're stuck with DSP surround modes.
Dec 27, 2009 | Audio Players & Recorders
RCA D52w15 will not turn on, flashes three times.
Replace you flyback transformer and Horizontal Output Transistor
Sep 28, 2009 | RCA HD52W59 HDTV Projection Television
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
EMAIL ME TO LILFLETCHER37@YAHOO.COM TO LET ME KNOW WHY MY TV SHOW THE WHOLE PICTURE BUT THE SIDE OF OF IT IS BLACK
Hi
this is horizontal deflection issue you need to check the horizontal yoke first
Thanks!
Mar 10, 2009 | RCA F36673ET 36" TV
My RCA 32", the picture seems to be riding up the screen.
hold menu botton in power once vol up once. vol up to76  ch top po3 aj pict size ith vol cont
Nov 30, 2008 | RCA F32650 32" TV
Turbo cut out, audi a3, 2.0 TDI, registered June 03, UK
Could be low oil level indicator tha auto shuts of engine if oil goes low
Nov 08, 2008 | 1999 Audi A4
Set video on older 36" rca colour tv Model # f3667et
take hammer and give it the good ole smasharoni as hard as u can
Jun 13, 2008 | RCA F36673ET 36" TV
Chaning input without remote
Radio Shack vende un adaptador para que conectes el juego por el lado de la antena este aparato entra por el canal 03.
Nov 08, 2007 | RCA F36673ET 36" TV
Sound ahead of picture
how are u setting it up rca outs to sterio rca ins ? ona ch or digital opti cable from tv back to setrio ? whats tvs output formatt at pcm or bitstream same with dvd
Feb 06, 2007 | Kenwood VR615 Receiver
Possible power supply problem?
Yep i can tell you what it is. The High pitched sound is the power supply soound when its overloaded and thats because the Horizontal output transistors shorted and this happened because of the flyback transformer went bad and /or the horizontal driver coil right off the secondary of the horizontal driver transformer and then the other side of this coil connects to the base of the horizontal output transistor. The part transformer cost about 35 to 45 bucks to the dealer and the transistor cost about 15 bucks. the total repair job cost about 175 to 225.00 after all said and done and some shops even may charge more ad there labopr rates may be higher. Good Luck
May 17, 2006 | RCA F36673ET 36" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
