Question about Microsoft Xbox 360 Console
Error problem on the xbox
Help
  • 89 Answers
What help?
Posted on Oct 06, 2008
My xbox 360 cant update and gives me an error 42fe-4451-1381-0300-c800-0036 help how to solve.
Consoles do this if they've been tampered with, according to Microsoft's help page. In bad news, you can't fix it.
In good news, you can still play your games offline. Restart your console and select "No" when the update prompt comes up.
You won't be able to use Xbox Live, but you'll still be able to use your console to play local games.
http://support.xbox.com/en-US/xbox-360/errors/error-code-c800-0036
Mar 06, 2016 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Xbox 360 error E74
This is a hardware issue
E73:
I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices.
Your best bet to resolve this issue is to contact xbox. They can be reached by calling 1800 my xbox.
Aug 25, 2010 | Microsoft Xbox 360 Console
Xbox 1 flashing red light and e73 system error
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
Feb 21, 2010 | Microsoft Xbox 360 Arcade
My xbox 360 says, system error, E 74. Can you help
take your xbox rap it up in 3 or 4 layers and let it over heat itself it is like a really hard reset
Dec 08, 2009 | Microsoft Xbox 360 Arcade
Lower right hand red light flashing
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Aug 04, 2009 | Microsoft Xbox 360 Console
Xbox F73 Fault
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
Jul 12, 2009 | Microsoft Xbox 360 Console
I get error code e-68
there's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
Jan 19, 2009 | Microsoft Xbox 360 Console
Error code from my xbox 360
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Jan 18, 2009 | Microsoft Xbox 360 Console
Xbox error code 05 & 07
error code 5 means the hard disk drive is not locked "retail bioses require a locked hdd
error code 7 means hdd timeout
im going to assume the hard disk drive is going bad or you did something wrong.
Nov 05, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
13 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
