Balboa Instruments Duplex Digital Panel 2 Pump Logo
Posted on Jun 10, 2017
Hot tub won't turn on. It had been working fine since we took it over in April. After the long fourth of July weekend we turned off the main breaker in the basement, drained the hot tub, cleaned, filled back up with chemicals, and turned breaker back on. However it won't turn on, it will flash "- -" in the display. We looked at the main circuit board and the gfci and everything looks alright as far as we can tell. Any guidance would be helpful!
5 Related Answers
nathan
  • 634 Answers
  • Posted on Jul 17, 2009
SOURCE: gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
radar001
Bob Korsu
  • 1051 Answers
  • Posted on Mar 21, 2010
SOURCE: My hot tub still trips the breaker,and i replaced
If your hot tub is pulling more amps than amps sent your breaker box, you'll keep tripping the breaker. Check the rating on the hot tub and compare that to the breaker rating. You may need to uograde the wireing. Make sure the wire gauge is up to code.
Anonymous
  • 351 Answers
  • Posted on May 12, 2010
SOURCE: Our hot tub keeps tripping the gfi breaker, but if
The GFI is sensing a fault, and tripping to protect you. If there is another GFI in the circuit somewhere then you could use that normal receptacle. I mean if there is a GFI in the main panel.
Please Vote !!
Ian  Hot Tub
hot tub plus
  • 77 Answers
  • Posted on Jul 06, 2010
Check the heater. The heater is the most likely cause of tripping electric.
If you're not sure what you're doing, please contact someone who does. Electricity isn't something that should be played around with especially when in close proximity to water.
Regards,
Ian.
http://hottub.synthasite.com
Ian  Hot Tub
hot tub plus
  • 77 Answers
SOURCE: Marquis Hot Tub, Instrument Panels (Balboa
The topside controls aren't fused so the fuses wont be the cause.
It can only be either the PCB, the topside controls, or a bad connection at fault. Check that they are plugged in correctly, make sure that the PCB is configured correctly for your topside controls.
It's rare for both the main and auxilary topside controls to fail. You can try plugging in another main topside control without fully installing it... at least you can then return it (ask whether or not return are accepted, I don't personally accept any returns if parts are specially ordered) if it doesn't cure the problem.
Regards,
Ian.
Engine wont turn
it seems like your starter may be going out. take it to Sears auto or Gateway tire to have them check it
Dominic 2820 won't get cold
The Dometic RM 2820 was working last night. This morning it was not cooling and now the front panel and interior light are not working. No smell of ammonia. Any help with this challenge? Thanks,
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My dryer had a broken belt so I installed a new one. According to the directions I could find online, it said to install the belt with the smooth side against the drum. Now that the belt is installed the...
If you have the belt down in the groove on the tub it won't work. The belt slick side goes to the drum and goes back like this:
I recently worked on one of these and took photos of the repair:
http://appliancejunk.blogspot.com/2011/09/old-maytag-dryer-belt-replacement.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
One of my customers had a goodman vsc060 compressor installed and I wanted to know if that is used in commercial also and how reputable of a unit it is compared to trane or other well known names.( His...
Goodman is are decent (builders grade) equipment. Not as good as Trane or Carrier but if it's installed correctly it should be fine. Goodman is mainly a residential brand but they do make some light commercial equipment which again is decent as long as it is put in correctly.
Mike
I have a Whirlpool 30 gal. electric water heater. Model E1F30HD035V, product # 0826237, dual element. It is in a seasonal home. Last weekend June 28 it worked fine. This weekend July 4th, it won't heat. I...
It is not unusual for an element to fail when turned on after non-use.
Turn off the power, and check the electrical resistance of each element. If either is infinite, then it needs to be replaced. Also, if only one is bad, then it can cause the whole unit to malfunction and not heat the water.
9helpful
3answers
Phillips/magnavox smart series
I have a Smart Series 32" Phillips-Magnovox TV I bought april '99. Around July 4 weekend 2008 it decided it just does not want to come on any more! Was working just fine before that...I can not find my manual. Any suggestions?
Thanks,
cely
[email protected]
Top Balboa Instruments Garden Experts
ZJ Limited
ZJ Limited
David Spradling
David Spradling
techdaipy
techdaipy
Level 1 Expert
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
