Question about Samsung S630 Digital Camera
CAMERA LENS STUCK OUT
THE CAMERA LENS IS STUCK OUT. IT WON'T COME ON TO TAKE A PICTURE. THE LENS WILL MAKE A SOUND AND MOVES A LITTLE IN LIKE IT WANTS TO WORK, BUT CAN'T.
  • 2 more comments
  • tyson05 Feb 16, 2009
    The same thing happen to me I put new batteries in and it still doesn't work
  • Condrel Apr 17, 2009
    my lens is stuck and everytime I try to turn it on, it makes a funny sound and shut off
  • haselhuhn575 Apr 22, 2009
    My problem is the lens is stuck outon my S630 and NOTHING is happening..I changed the batteries and tryed to hook it up to the computer and still nothing..help!! I am going on a few trips soon and NEED my camera.
    Thank you in advance for your help! :O)
    Michele
    haselhuhn575@yahoo.com
  • dancechik364 May 17, 2009
    Mine is stuck out and when i push the power button the green lights come on and then nothin happens. I tried pushing on the lens, I tried new batteries i tried smacking the stupid thing but nothing is working ahhh!
Chech and make sure that your lens isnt bent to the side, because i had the same problem and as soon as i bent my lens back it turned on and worked like new
Posted on Oct 04, 2008
If the lens of your camara is sticking out make sure your batterys are inserted right, or put new ones in. I did this and it worked again like a charm. Hope this helps..
Posted on Jun 08, 2009
    Sergeant:
  • 359 Answers
Push the lens assembly back into the camera with your thumbs gently yet firmly until you hear a click, that should fix it.
Posted on Sep 02, 2008
2 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: i have a samsung digital camera and i dropped it
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
Cannon Ixus 115 lens stuck open,(now takeing apart) any tips
Sounds like you are having drive motor assembly problems,the unit that moves the lens in and out. Be very careful as you can do more damage than good if you are not careful.
Jan 27, 2013 | Cameras
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
The lens opens and makes a ticking sound but light stay orange
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 15, 2009 | Olympus FE-210 Digital Camera
Lens stuck in
You'll need to either take this to a qualified repair shop or replace. Depending on the cost of the repair (Which I would guess as significant) it will more than likely be more economical to replace.
Jul 08, 2009 | Pentax Optio 550 Digital Camera
DSC-w70 stuck lens
there actually is a little gear inside that moves the lens and since you already opened it make sure the gear is there and moves. LOTS of problems with these cameras....
Jul 30, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Samsung S630 Digital Camera Logo
184 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
