Question about Whirlpool Refrigerators
Whirlpool GD5NVAX fridge does not seem to be cold enough. The unit is just over a year old
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
SOURCE: Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Posted on Nov 17, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
Calibration screw fridge
Try the thermostat on it's lowest setting first. If it doesn't switch off soon enough and gets too cold, you can get different thermostats from your supplier. A bottle fridge thermostat would suit.
Apr 21, 2012 | Whirlpool Refrigerators
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Whirlpool fridge and freezer 5 years old, won't stay cold enough
Brush are vac coil in back of fridge, take everything out of freezer and clean inside make sure any drain lines in freezer and bottom of fridge are unobstructed, a small piece of wire ran in and out of these tubes will unstop them. This fixed my fridge.
Good luck
Aug 16, 2009 | Whirlpool Refrigerators
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Whirlpool fridge with top freezer.( no ice maker )
check if you have frost build up at the back side of the freezer section.
if you do, then it is a defrosting problem.
you could have a problem with the defrost timer, the defrost heater , or the bi-metal.
if there is no frost accumulation, that would be something more and you have to elaborate on what you observe with the unit to help me further troubleshoot your unit.
tnx 4 using fixya,
drcool
Sep 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
