Question about Dell 2600 Notebook
Dell 610c will not turn on with adapter
My Dell 610c will not turn on with adapter but works fine on Battery alone. If its up & running and I plug in the adapter it goes off instantly - not a shutdown. The battery does not charge (!) and I checked the power from the adapter as 20V. The adapter light stays on when i plug it into the Laptop. But the Laptop light does not indicate power is plugged in.
Have you seen this before?
thanks
  • Len Dec 06, 2008
    I checked the power from the external adapter, its OK till it is connected to the laptop. So, I assume the adapter you mention is in the box or on the MB - correct?
    I looked at the repair manual from dell, I believe the darn thing is integrated on the MB. But if that's not the case, let me know.
    Thanks much.
The adaptor is not defective.
I had the exact problem, switched adaptors and the problem remained.
There must be a problem with the laptop motherboard or power input.
Posted on Nov 03, 2008
    Sergeant:
    Champion:
  • 362 Answers
Yes the ac adaptor in the unit is defective they short out you will have to replace it the part is only 9.00 but labor can be expensive. thank you james
Posted on Aug 26, 2008
  • 1 more comment
  • james kilgore
    james kilgore Dec 05, 2008
    yes the power inverter is bad give me the part number and i might have it.
  • james kilgore
    james kilgore Dec 06, 2008
    it is a seperate board in the laptopits not too hard to change and isnt very expensive
  • james kilgore
    james kilgore Jan 05, 2009
    somtimes the if cable to the power sw goes bad use a umper wire at tge zif anf if it starts thats the problem
AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
So your saying the charger will charge the battery, as long as the laptop is off...But when it is charged, you remove the ac adapter, start up the laptop, running on battery power alone, then hook the ac adapter to it, and the laptop cuts off..???
Apr 27, 2014 | Acer Aspire 8930G Laptop Charger...
Dell Inspiron 6000 laptop periodically shuts OFF
You've checked the p/s and it has volts out. Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone. Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 04, 2010 | Dell Inspiron 6000 Notebook
I have a dell vostro 1700 that will not start with battery in and on mains it goes into diagnostic boot
when you say the battery is in, you refer to battery is actually plugged in while the ac adapter are connected? it means the laptop works fine with ac adapter alone? try updating the bios download from the support.dell.com
regarding the diagnostics. the partitioned where the diagnostics should be into was might wipe out during re-installation or something.
Mar 28, 2010 | Dell Vostro 1700 Notebook
Battery light on dell latitude d410 continously flashes yellow/orangish. Does this indicate a bad battery. Works fine with cord plugged in.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
Mar 17, 2010 | Dell Latitude D410 Notebook
When adapter plugged in computer starts then goes
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | Dell Inspiron 6000 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Battery is not charging properly ....?
Have you checked the bios battery status and bios version? first check if battery has charge if yes then update the bios. also try to remove batt and use ac adapter alone and check if laptop has sufficient power. try connecting ac adapter to a diff wall socket. if laptop works fine with ac adapter alone then batt might has problem.
Sep 28, 2009 | Dell Latitude D620 Notebook
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Dell Latitude C540 screen goes dark when adapter is pluged in
Right click on the battery icon on screen and set the power and screen brightness as you require.
May 02, 2017 | Dell Latitude CP DC Board Graphic Card
Dell 2600 Notebook Logo
82 people viewed this question
Alun Cox
