Question about HP Officejet 5610 All-In-One InkJet Printer
Tried ubplugging like you suggested
Sorry, thought I was supposed to rate you each time I tried something new .
I tried unplugging printer from computer, and replugged, etc
I have been on line with hp installing printer software from their site in hopes it woudl be fixed ( thinking my disk was corrupt?) Anyway nothing yet.
Maybe I will simpoly unplug EVERYTHING and replug...hoping I don't screw it up worse than it is now.
  • Carole2
    Carole2 Aug 27, 2008
    Going to take cable to Staples in the morning to see iif it needs replacing.
    The computer does not detect a scanner or printer at all
    Carole
  • 928 Answers
Its possible that the installation had an error while online and the CD.
Go to control panel then select add/remove programs and make sure that all instances of yiour HP printer software is removed. Remove the printer from your computer. After that shut down the computer and then turn it back on. Put the CD in the computer and then run the CD and follow the directions. It should be the one to tell you when to plug in the printer. if in case it gives an error at the end with it not finding the printer. Dont uninstall the software just look for anything that has a question mark or exclamation point in the device manager. if so right click on that and hit update driver but make sure the CD is in the drive.
Posted on Aug 26, 2008
  • Thomas Lim
    Thomas Lim Aug 27, 2008
    Ok so that means it indeed is the cable. Have them check it then get back to me. After that it should be fine.
Aluminium foil melted on Smeg black schott ceran cooktop. Too stubborn for razor blade. Any suggestions?
Sorry to read about your problem, I hope this helps you out.
try some oven cleaner, and let it soak...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Microwave Ovens
I recently installed a new garbage disposal and since then my dishwasher won't drain. Is there something i'm suppose to reset or something?
remove you garbage disposal, look at the hole where you hooked the dishwasher. get a large screw driver and hammer and place in hole, and knock out the plug. if you put your finger in the hole, you will see it does not go thru... REMOVE THE PLUG AS IT FALLS INTO UNIT.
3 Thumbs - Helpful
Jan 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool gold washing machine(top load).Seeing alot of water,so i took the rinse/drain hose off the back to make sure it wasnt cloged.I then kept it of but started a normal wash and as soon as the water...
no it is not normal, i suggest you contact a service company. A repair will cost alot less than a new washer...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Whirlpool Duet GHW9200LQ front load washer will not turn on. The only light that is illuminated is the bottom cycle light (it says controlled or something, the letters have worn off). I tried...
you have a complete failure, i suggest you contact a service company, since your unit is dead, and you tried to reset the unit
3 Thumbs - Helpful
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
All of a sudden my Kodak ESP5250 "can not read the memory card". I have tried both the existing memory card (one I've used repeatedly in this printer) and a new one. The printer was purchased in June...
this is probably due to damage to the memory card or the printer itself.the best way is to try using the memory card on another printer or compatible device and see if it works(this is just to clarify where the problem is coming from) after this you can try dusting or cleaning the memory card port and wiping off dust from the panel of the memory card and see if that helps..hope this was helpful?
Oct 21, 2010 | Kodak ESP5250 All-In-One InkJet Printer
I get a message hand-set not in range. No charge light. Hook up appears OK. Second home phone works properly. Prior to problem I tried to dial a local no. but entered 8 nos. Phone says searching or...
Dialing the 8 numbers should not cause a problem.I have a few suggestions,you may have tried a couple already.Hang up the problem phone on the base unit for about 30 seconds.If that does not help,remove the battery for a few seconds and try the 30 second hang up again.Try unplugging the base unit for a half minute.I am trying to get it to reset itself and link to the base.Is the second phone part of this system too?We had a Uniden and I personally thought it ended up being garbage and will probably never buy another one.If you end up deciding to buy a new phone,the new technology is DECT 6.0 and is supposed to have better range from the base,clearer sound to name a few things.The strange thing about it is that it operates at 1.9 GHz.Also,if you decide on a new one,google DECT phones.There are all kinds of forums about peoples opinions/ratings of ones they have bought and used for a period of time.If you have any questions,just comment on this post and I will get an auto email saying you posted.Good luck! Greg
Aug 14, 2010 | Uniden Lands Phones
Printing Phaser 8550
that is a part of that printer design. Something sadly you can not get rid of. Believe me, I have tried, and Xerox engineering told me that is part of how the machine is supposed to work. Wish we could eliminate that.
Mar 26, 2009 | Xerox Phaser 8500/DN Printer
Refilling my Yellow ink
The problem here might be the cartridge. You need to replace it.
Oct 15, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
